查看: 1789|回复: 0
Wallys/IPQ4018/IPQ4028 2x2 2.4Ghz 2x2 5Ghz Industrial-grade //wifi5 Support 1...
发表于 2022-10-21 11:35:48 | 显示全部楼层 |阅读模式
Wallys/IPQ4018/IPQ4028 2x2 2.4Ghz 2x2 5Ghz Industrial-grade //wifi5 Support 11ABGN/AC
IPQ40x8/IPQ40x9 is the industry's first Wave 2 802.11AC SoC WiFi solution from Qualcomm Atheros, representing another leap forward in home wireless networking. It is understood that the chip models included in this series are IPQ4018, IPQ4019, IPQ4028 and IPQ4029. Ipq40x8/40x9 is Qualcomm Atheros' latest smart gateway platform that supports dual-band 2X2 MIMO, enabling manufacturers to bring Wave 2 802.11AC into the mainstream.
IPQ40x8/IPQ40x9 supports multiple configurations: dual 5GHz, 2.4ghz + 5GHz, and even supports 60GHz band through PCI Express interface. Meanwhile, IPQ40X8/40X9 has rich peripheral interfaces, including USB 3.0, LCD, SD/eMMC, multi-channel audio interface, LTE and Ethernet.
MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/QCN6024/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882 /AR9582/AR9531/AR9344 /AX200NGW/ AP9342
With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective routerboards and wireless network cards.
In the complex market, Wallys products stand out and are affirmed by partners. From 802.11 a - ax, Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win -win cooperation.
BY:Wallys Communications (Suzhou ) Co., LTD
DR40X8H
https://www.wallystech.com/Routerboard/DR40X8H-Qualcomm-IPQ4018-IPQ4028-2T2R-Dual-Band-2-4GHz-5GHz-high-power-support-MU-MIMO-802.11ac-Wave-2.html
https://www.youtube.com/watch?v=cqd2kPCg73E
Featuring with industrial-grade IPQ4018/IPQ4028 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range;
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Absolute Maximum Rating
Parameter
Rating
Unit
Supply Voltage
24V~48
V
Operating Temperature Range
-40 to +60
oC
Storage Temperature Range
-65 to +105
oC
Operating Humidity Range
5 to +95 (non-condensing)
Storage Humidity Range
0 to +90 (non-condensing)
Hardware Specifications
Symbol
Parameter
CPU
IPQ4018 (Quad core ARM Cortex A7 at 710 MHz)
Antenna Connector
2 x 5G MMCX connectors;2x2.4G MMCX
10/100/1000Mbps Gigabit Ethernet
2xRJ45
SFP connector
1xSFP fiber module connector (optional)
3G/4G connector
1xminipcie 3G/4G connector support with two sim card
USB connector
1xUSB 3.0 connector
POE
24V~48V passive POE
DC Jack
24V~48V power supply
ROHS Compliance
YES
Dimension
115mm x 105mm x 16mm
Nor Flash
2MB~32MB
Nand Flash
128MB
DDR
256MB
