查看: 2244|回复: 0
Wallys||QCA9531/AR9341,high power MIMO,2.4G,30dBm 2 x 2.4G MMCX connectors/5M...
发表于 2022-10-31 13:44:14 | 显示全部楼层 |阅读模式
Wallys||QCA9531/AR9341,MIMO,2.4G,30dBm QCN9024/QCN6024/QCN9072/QCN9074 2 x 2.4G MMCX connectors/5M/10M/20M/40M Bandwidth/high power
After 15 years announced AR9341 qualcomm chip production, many manufacturers began to give up in succession 9341 chip production, although the product in the market, high using rate, maturity is good, but as the production, announced that in the subsequent join operation industry customers are beginning to give up this chip products, the reason was that the subsequent support terminal and the production of each big manufacturer, Faced with upgrading difficulties, production difficulties, selection of products to replace.
In view of this situation, in 15 years, manufacturers began to use Qualcomm to acquire Atheros after the release of WIFI chip QCA9531 instead of 9341 as the mainstream solution of intelligent router, in fact, since 2010 after Qualcomm released 9341 chip, WIFI solution widely used this chip, intelligent router development rapidly, The weakness of the AR9341 became apparent, which led to the launch of the QCA9531 chip in 2013.
AR9341 is familiar to everyone, but what are the specific differences with AR9531?
Both products are 11N wireless standard, 300M bandwidth, 2*2MIMO technology, AR9341 main frequency is 550MHZ, QCA9531 main frequency will be higher, up to 650MHZ, improve CPU, reduce power consumption, so that the chip heat is lower, both chips support USB interface. QCA9531 also supports MINIPCIE interface, can expand the application of 5G dual frequency and LTE data module, more in line with the development needs of intelligent router,
While adding external interfaces, QCA also supports large memory, up to 128MB, which is convenient for business intelligence WIFI data, advertising and other services. The AR9341 memory (maximum support 64MB) will not be limited as before. QCA9531 improves the performance and expands the memory and interface, optimizes the radio frequency, and can be associated with more users. In terms of the amount of tape, the amount of wireless tape of 9531 can reach about 35, the amount of wired tape is about 120, far more than the amount of wireless tape of 9341 is about 30, and the amount of wired tape is about 80.
DR531
QCA9531,MIMO,2.4G,30dBm
Featuring with industrial-grade QCA-Atheros AR9531 (550 MHz)chipset. DR531
Integrated with 1 x 2.4G high power (up to 30dBm aggregate ) Radio Card
Supports 2 x 10/100Mbps FE Port.
Support LTE/WiFi Card
Supports 2 x 2.4G MMCX connectors.
Support 5M/10M/20M/40M Bandwidth.
Support 1 x buzzer(Optional)
Supports operating frequency from 2.312 GHz to 2.7 GHz.
RoHS compliance ensure a high level protection of human health
! D5 V4 m  V6 ]* ^- e- Z
Hardware Information
CPU
Qualcomm-Atheros AR9531
System Memory
64MB(max 128MB DDR2 optional)
NOR Flash
8MB
Power consumption
2.04W(Board Only)
Antenna Connector
2 x MMCX
Power Connector
1 x DC JACK
LAN Connector
2 x 100M LAN
Power Solutions
DC Jack Input: 12-24V, Passive PoE: 24V
ROHS Compliance
YES
Humidity
Operating: 5% to 95% (non-condensing); Storage: Max.90% (non-condensing)
Temperature Range
Operating: -20?C to 70?C; Storage: -40?C to 90?C
Reset Button
Software reset,Hardware reset(Optonal)
Extras
Serial Port, JTAG, Surge Arrestor, Watchdog Timer
Dimension
95mm x 85mm x 17mm
4 C( u' _1 i+ P) B( n
The router supports wallys mini pcie card, QCN9074 / QCN9072 / QCN9024 / QCN6024.
4 l3 |, t  g9 m3 N( Y5 L/ n) ?5 H
Let's take a look at the detailed parameters of these cards. If you have any questions, please feel free to contact us
1 z' f7 h  o% W: |$ F6 p+ ^8 J1 a+ X
■ Qualcomm Atheros QCN9074
■ 6GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
  X* Q/ u1 r6 g& O, Q
Symbol
Parameter
Chipset
WLAN Host Interface
System Memory
2Mbit serial I?C bus EEPROM
Standard Operating Voltage
5V
Operating Systems
QSDK
Host Interface
M.2 E Key
Antenna Cable / Port
4 x MMCX Connectors,4T4R
Frequency Range
5.925GHz-7.125GHz
Data Rates for WALN
Channel Spectrum Widths for WLAN
Support 20/40/80/160MHz at 6GHz
Modulation Techniques
OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
Temperature Range
Operating: -20°C to 70°C, Storage: -40°C to 90°C
Humidity
Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
Certification
TBD
Power Consumption
TBD
Reference Design
PN02.7
Dimensions (WxHxD)
57mm x 63mm x 6mm
4 Z: ^: ?+ I( o: ^
8 q( w; n( ?  e+ q( }
This mini pcie card has three frequency bands, including 2.4G, 5G and 6G, depending on the customer's own project requirements.
Wallys has a history of 10 years, so it can be said that its hardware and software development design is very mature. It independently designs and develops software to support the current trend of wifi, including openwrt, MT and QSDK, which has been recognized and trusted by more customers.
There are many companies in the market that develop and design wireless motherboards (moudle, antenna), but for some reasons, the design and development is complicated and the cost is high, so more companies are not willing to take on such customers, and wallys can help you complete the project, which is also an advantage.
For example, if you buy a board from another company and you need wallys' moudle, but the board may not be compatible with moudle, this problem is troublesome, and wallys can help the customer solve the problem to some extent.
More customers can get technical support, so as to obtain more customer sources. This is not only for helping customers, but also for wallys' strong hardware and software development ability to gain customers' trust and support.
wallys also supports custom development if the client has a custom product project.
More questions can be contacted by email, at any time for you to answer questions
Skype/EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
* Y4 f2 C, T; @6 D7 ?% E) n. Q2 G7 ?9 L
1 }2 X( a- `- F/ o; K( [
7 s$ a% e9 c* w- a4 N; A# R& o- E
