发表于 2022-11-3 13:51:56
显示全部楼层
用另一种方式也有问题; ~4 k* e0 G+ U. Y, x1 a. P
module Euler
) I$ V% F) C2 q; Y. H(
1 B- ^1 @3 ]* cinput wire clk,0 f1 g. Q o# }( h ~) Y# T
input wire [31:0] x, //定义输入量,单精度32位浮点数3 A( t$ x" o8 w
input wire [31:0] y,
0 t0 ]& ~, m! V) n. ~4 I- X8 M4 H6 N4 L$ Binput wire [31:0] z,! m3 C% w" j8 c: Q/ m" o
input wire [31:0] h,
^% d; {; m& `- l- aoutput wire n1
$ |( ? q: f! i) `2 Q+ h);
- F$ w5 g3 q) g2 c( U$ k6 B s4 T: _1 n0 x6 b
0 V& N- Y. @3 w" K1 }+ g! \6 V) U
function [31:0] g;//加法器函数
9 A2 p( l) d% x5 r- f% K input reg [31:0] x;
0 y8 \$ p0 l0 d0 B1 L4 K0 A input reg [31:0] y;( Q, v# D/ v7 t! ?' r. q w( I9 j
reg [31:0] z;
* N5 y: t* B2 `( X% ^! ]begin
6 z7 G$ a! l& I$ f' q- `4 Vadd_sub add_sub_inst(
% M1 {( T1 c# |( I //调用浮点数加法IP
S+ g+ s+ I1 Y! f3 S. J.clock ( clk),, O9 O" R( m% L
.dataa ( x ),
' |, P$ ?- P* r7 u* q9 t.datab ( y ),3 e6 p6 F9 X# f( z9 l
.result ( z )6 Y( o2 [; O/ A7 }4 X) G2 y* ^
);9 c$ h9 d$ A9 k' w9 _; C
g = z;" M X! q0 f5 B
end6 A3 K! i! B* y- P- B/ j2 A6 f
endfunction. V% L4 c3 k: r' W7 p8 C0 R1 |
8 Z, g1 _5 G& k% K1 j
9 H( k# V7 ?! V+ T$ p
/ X5 ?0 K2 M8 ]& M, c; f- I/ [8 e: E7 W }1 |4 v8 c* Y s
function[31:0]f; //乘法器函数
, N. l% V+ Y/ j. `: o- l input reg [31:0]x;
" ]/ J/ i% Y! a6 g( c input reg [31:0]y;- Q' E8 T* Z1 |4 p: ?/ ^6 O
reg [31:0]z;: q5 D D( Z+ \% ?
begin
" L- \# x# P$ z" q" [mult mult_inst( 1 V9 s4 p4 O- H. f1 q1 v
//调用浮点数乘法IP
* c, O# F r) D* L.clock ( clk ),
9 F' n# w O: {1 y2 R) a8 [2 D.dataa ( x),
' e- G5 m) d' r8 y$ C$ Z1 y.datab ( y ),* F4 }8 x9 B7 U" `, @
.result ( z )1 `4 {5 j, J U0 |, r* M
);1 c, U2 u- m8 L% f
f = z;
( N7 N3 ~! K; V5 d% x6 Q* x end
1 o! g* X6 [( G/ i, d7 t! \ H7 X1 \7 |endfunction, d( I% o' E: f0 C
* S) e1 i& }- w; d0 q6 K& a/ E
0 m: k: @# u! O; W/ yreg[31:0] z11;
0 C- W" E: i! F, C5 Jreg[31:0] z1;
3 ^: `$ P: j! [) Nreg[31:0] y11;
% {# }0 Q6 d2 ?0 U$ L& X7 ^reg[31:0] y12;3 f3 p* e( [. k+ d7 a8 k
integer n; 6 z" B# @; a3 C& Y- o, k8 L: E1 p$ M
! {7 P+ G' n0 X* A, J9 ]
1 V( i! |+ t3 d; uinitial: R! {7 e; \- [# ]# a6 M
begin' S' G, x7 }' Z* n! b
//开始迭代. w( t. a. P6 [, D( L8 E' f, W
for (n = 0; n < 10; n=n+1)
, `; |9 Q' P$ E2 Q, t1 _, M3 c. i* r begin
/ k" `! q7 J! G' z% I# I x = g(x,h);$ A8 c j& ?* n1 L: Y9 L5 v
z11 = f(x,z);% c: b P* ]; [ O0 p/ R
z1 = g(z11,y);
1 d8 [! }9 V/ c" c r2 o6 B y11 = f(h,z);
$ b/ Q y" v5 | y = g(y,y11);* `1 }5 a* r! v6 D6 u
z12 = f(h,z1);
5 m. g* e( z4 w z = g(z,z12);
1 g* v4 i+ n V" D: i) z) x2 n $display ("n=%d x=%b y=%b z=%b\n",n,x,y,z );
( {6 y' M# W. I, X5 t1 j, m | end
8 `8 \+ e9 d1 u3 x2 }3 {end6 N3 l* v7 d( m& W( D$ e
endmodule! j& ]2 |8 {$ `/ ?7 Z
错误报告是% E4 {% |* I: z6 P. P+ S$ B6 P! `
Error (10170): Verilog HDL syntax error at Eeler.v(16) near text "("; expecting ";"
( j" z- R. A3 u0 g) Q" ^! HError (10170): Verilog HDL syntax error at Eeler.v(33) near text "("; expecting ";"
. F. M( H1 w& |1 QError (10112): Ignored design unit "Euler" at Eeler.v(1) due to previous errors |
