查看: 1748|回复: 2
请求高人指点 These LMI constraints were found infeasible
发表于 2022-11-9 22:01:53 | 显示全部楼层 |阅读模式
出现These LMI constraints were found infeasible
但运行出结果了,结果两个K相同
Solver for LMI feasibility proble***(x) < R(x)
     This solver minimizes  t  subject to  L(x) < R(x) + t*I
     The best value of t should be negative for feasibility  Iteration    :     Best value of t so far
* switching to QR
      1                         4.286890
      2                         1.800517
      3                         1.510866
      4                         1.255956
      5                         1.255956
      6                         1.255956
      7                         1.187347
      8                         1.187347
      9                         1.111091
     10                         1.111091
     11                         1.093537
     12                         1.093537
     13                         1.083196
     14                         1.083196
     15                         1.083196
     16                         1.082546
     17                         1.082546
     18                         1.082363
     19                         1.082363
     20                         1.082363
     21                         1.082344
     22                         1.082344
     23                         1.082344  Result:  could not establish feasibility nor infeasibility
           f-radius saturation:  3.677% of R = 1.00e+009
Termination due to SLOW PROGRESS:
           t was decreased by less than 10.000% during
           the last 10 iterations.
tmin =      1.0823
xfeas =   1.0e+007 *      0.0000
     0.0000
     0.0000
     2.6020
     0.0047
     2.5974
    -0.0000
     0.0000
     0.0000
     0.0000
    -0.0000
    -0.0000
      2                         2.463023
      3                         1.909151
      4                         1.493367
***                  new lower bound:     -2.511580
      5                         1.493367
***                  new lower bound:     -1.854244
      6                         1.493367
***                  new lower bound:     -0.897262
      7                         1.370090
***                  new lower bound:      0.794775  Result:  best value of t:      1.370090
           f-radius saturation:  85.760% of R = 1.00e+001  These LMI constraints were found infeasible
tmin =      1.3701
xfeas =      0.3071
     0.0511
     0.0110
     5.9708
     0.2542
     5.9783
    -0.1508
    -0.1385
    -0.1293
    -0.1508
    -0.1385
    -0.1293
P =      0.3071     0.0511
     0.0511     0.0110
S =      5.9708     0.2542
     0.2542     5.9783
K1 =     -0.1508    -0.1385
    -0.1385    -0.1293
K2 =     -0.1508    -0.1385
    -0.1385    -0.1293
发表于 2022-11-9 22:02:37 | 显示全部楼层
请问,楼主后来问题怎么解决的啊?遇到找不到可行解的时候,应该怎么怎么办呢
联盟顾问
发表于 2022-11-9 22:03:03 | 显示全部楼层
同问,楼主解决这个问题了吗,十年之后我也想知道为什么会这样,处于可行解和不可行解的边缘,但是出来了一个可行解。
