查看: 1663|回复: 0
Wallys industrial wifi5 router /IPQ4019 IPQ4029 ,802.11AC 2x2 2.4G&5G
发表于 2022-11-25 16:43:36 | 显示全部楼层 |阅读模式
Wallys|QSDK industrial IPQ6010 IPQ4019 IPQ4029 802.11ax/ac support QCA9880/QCA9882 moudles Outdoor AP Plastic
wallys, a technology company that develops, designs and manufactures wireless communications products, has 90% of the world’s customers and is a supplier to facebook.
From 802.11n to 802.11ax, it has been moving forward, and has been trusted and supported by more and more customers.
wallys also supports custom development of software and hardware, including customized products.
With a feature set that includes industrial-grade IPQ4019/IPQ4029 chipset, the [product name] is an ideal solution for your 2.4GHz and 5GHz communications needs.
The following are the best-selling products of Wallys. Let’s take a look at them together. You can contact us at any time if you are in need, or enter our company’s official website to check more product information.
Feature:
Featuring with industrial-grade IPQ4019/IPQ4029 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
Support fixed data rate
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Our Firmware supports all the modules of Quectel
DR40X9 is equipped with integrated 2x2.5G high power radio modules and 2x2.4G high power radio modules that support 4.940GHz to 5.825GHz frequency range and can handle data rates up to 80MHz bandwidth.
This product also features a 5MHz/10MHz/20MHz/40MHz/80MHz bandwidth. In addition, it has 11ABGN/AC support for fixed data rate applications such as video streaming and storage among others.
https://www.wallystech.com/Routerboard/DR40X9-Qualcomm-IPQ-4019-4029-DUAL-BAND-802.11AC-WAVE2-MU-MIMO-ONBOARD-WIFI-RADIO-EMBEDDED-BOARD-supporting-LTE.html
DR6018 DR6018-S DR6018C V01 DR8072 V01 DR5018 DR40X9 DR3G11 DR2G41 DR7915 DR9074-5G DR9074-2.4G DR9074-6E DR600VX DR900VX DR882
For more products please visit: https://www.wallystech.com/product.html
Follow us in the Youtube: https://www.youtube.com/channel/UClmu7LBz_OWxe2VckkQr3tw
