查看: 1854|回复: 0
QSDK industrial wifi router/based on IPQ8072/IPQ8074 IPQ6010/IPQ5018/IPQ4019 ...
发表于 2022-11-29 10:24:49 | 显示全部楼层 |阅读模式
QSDK industrial wifi router/based on IPQ8072/IPQ8074 IPQ6010/IPQ5018/IPQ4019 support QCN9074/QCN9024 wifi moudle! q8 w- l1 n5 X8 s. X1 B
Today I will introduce Qualcomm's high-end wifi6 router. The chip is based on IPQ8072/IPQ8074. Due to market reasons, the price is more expensive than other common chips IPQ6010, IPQ5018 and IPQ4019.* i% i3 D& ~, ?7 i
However, no matter what your project needs are, the software and hardware development team of wallys can meet them. wallys has a strong software and hardware development team and has won the support and trust of many domestic and foreign customers.
9 ]  J  l: D! }; G4 P2 Q9 A9 DLet's take a look at the wifi6 router based on the IPQ8072/IPQ8072A chip.2 o5 @) c+ S8 m* n" C% y
DR8072 V01  _7 Q- e& h0 D- N
6 e Support WiFi Card, ax, 802.11 QCN9074 / QCN6024 / QCN9024
& C  J5 ~9 ^: L- E. U2 [8 I; SIPQ8072 4x4 2.4G & 5G 802.11ax
/ v3 b8 _5 n! G# A2 B6 e, jIt has SFP, which you can customize to choose how much G you need.6 S( T# y! {% }. D
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
0 \' ^% c& y2 [, m■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate3 c2 e, d" q3 K' Z! P
■ 8 MB NOR Flash, 256MB NAND Flash (NAND Flash can be up to 1GB as optional)7 `8 u7 y- c% q7 J0 |  _. j5 J! i
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
" X% v% }) Q. ^■ Supports Dynamic Frequency Selection (DFS)
* b1 N! s1 j6 g- W' Q6 W■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
9 H* H0 B5 o4 D2 N2 ?■ M.2 connector can support QCN9074 production0 b* D- m, I) Z% a0 I+ c
/ P( [& \; h/ ^% O
, `; e2 H/ L% O' R! J$ oDR8074A(HK01)) K, L+ W- ~1 F6 _3 B( A
IPQ8074A 4x4 2.4G 8x8 5G 802.11ax
& E! g% ]/ }8 F& {' _% y& Z■ On-board 5GHz radio, up to 4804Mbps physical data rate 32MB NOR Flash, 256MB NAND Flash
# }" R  K: d' S  s$ m- E5 w) k■ On-board 2.4GHz radio, up to 1147Mbps physical data rate
" P  O. f+ |4 p, X6 [■ Support 11ax TX Beamforming1 j; X" a8 Q/ e- Y2 _! b4 W
■ Support 11ac/ax MU-MIMO DL and UL1 k4 Z  z! U3 H# G6 X: l. s8 c
■ Support OFDMA DL and UL
: a' y" r% p  C& C5 E■ Tri-band support with 5G SBS (4x4/5GHz + 4x4/5GHz) + 4x4/2.4GHz
; @9 v7 s6 A1 s1 O■ Supports Dynamic Frequency Selection (DFS)
6 ~$ ~; N* F; o! @
8 a4 E% O9 N+ U/ e# W* N/ dwallys has many wifi5/6 routers, and also produces wifi moudle, antenna, AP and so on.
( k' l( P7 g) V: [' QFeel free to contact you if you need anything.
( Q2 {8 P/ j! x
Commercial processes and communications are all managed utilising wireless technologies, and the number of users, devices and apps are only going to increase.??Therefore, it is essential to have a robust, secure and high performing WiFi solution that is future-proofed, mobile, and scalable.??Not only is business WiFi vital for your workforce and organisation, it is now imperative for visitors to be able to access a secure guest wireless network.
Wallys?has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless?modules. Customization is also supported, We have 90% of the world market,?We're a supplier to Facebook.
4 o$ P% j9 p2 T- S# `- [, P8 z
