查看: 1860|回复: 0
Wallys//QCN9074/QCN9024/QCN9072 /4x4 MU MIMO Dual Band MiniPCIe/industrial wi...
发表于 2022-12-2 14:36:33 | 显示全部楼层 |阅读模式
QCN9074/QCN9024/QCN9072 4x4 MU MIMO Dual Band  MiniPCIe/industrial wifi6 moudle
Welcome to Wallys' new product website. Next, I will introduce a new product DR9074E
The DR9074E chip uses QCN9074 or QCN9024. Either of these two chips can be used. I will introduce the differences between these two chips later. In addition, it is based on QCN90X4 Chipset is an enterprise wireless module integrated with 4x4 MU-MIMO Dual Band Wireless Module designed specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment in factories, warehouses establishment.
The DR9074E is very similar to our other product, the DR9074-6E. At that time, they have some differences. The card slot of the DR9074-6E is M 2. But the DR9074E is the card slot of the miniplane. Two different products also provide customers with more choices. These two cards belong to the 6G band, and their chips are QCN90X4 series and 4 * 4MIMO,
Except that the card slots are different, their hardware and software are basically the same, so their applications are also the same.
Now let me introduce the chip QCN9074 and the chip QCN9024 to you:
QCN6024 for 5G can run 4204Mbps. Support 8 networking. The second model: TP XDR6080. The QCN9074 used in the 5G chip is stronger than the 6070, and the 2.4G chip can also run up to 1148Mbps. It has 8 independent FEM power amplifier chips, strong signal, 2.5G network port + 4 full Gigabit network ports.
Finally, let me introduce myself and our company:
Hello,This is Tina from Wallys, we are a Mfg of networking devices like cellular routers, NICs, CPE/AP, antennas etc
Our current products portfolio are based on Qualcomm and Mediatek platforms
Hardware customization and software integration is our speciality, OEM/ODM turnkey solution, aslo, we can work with you under JDM mode to develop new products together
By sending this text, i am seeking an potential business opportunity with you
If you are interested or looking for any networking hardwares, feel free to share me your detailed requirements, i can do a proposal accordingly
Thanks for your prompt attention and looking forward to your favorable feedback
Sincerely,,,
The following is the product DR9074e:
Features
■ Qualcomm Atheros QCN90X4
■ Maxim Tx power 20dBm per chain
■ Date Rateup to 4949Mbps
■ Support  5.180~5.825Ghz or 5.925GHz-7.125GHz or  5.180GHz- 7.125GHz
■ MiniPCIe connector
■ PCI Express 3.0 Interface
Applications
■ Security Surveillance
■ Commercial radio coverage
■ Hotel Wireless application
■ Forest fire protection engineering
■ Country coverage
■ Some special scene application
Absolute Maximum Rating
Parameter
Rating
Unit
Operating Temperature Range
-20 to 70
oC
Storage Temperature Range
-40 to 90
oC
Operating Humidity Range
5 to +95 (non-condensing)
Storage Humidity Range
0 to +90 (non-condensing)
Hardware Specifications
Symbol
Parameter
Chipset
Qualcomm Atheros QCN9074(QCN9024)
WLAN Host Interface
System Memory
2Mbit serial I2C bus EEPROM
Standard Operating Voltage
3.3V
Operating Systems
QSDK
Host Interface
MiniPCIE
Antenna Cable / Port
4 x MMCX Connectors,4T4R
Frequency Range
5.180GHz-5.852GHz or 5.952GHz-7.125GHz
Data Rates for WALN
Maxim TX power 20dBm per chain, up to 4949Mbps
Channel Spectrum Widths for WLAN
Support 20/40/80/160MHz
Modulation Techniques
OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
Temperature Range
Operating: -20°C to 70°C, Storage: -40°C to 90°C
Humidity
Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
Certification
TBD
Power Consumption
15WMaximum),9.5W(Normally)
Dimensions (WxHxD)
30mm x 50mm x 14.5mm
If you are interested, please click the link below to learn more about the product. Or contact me at the following email address, thanks!
https://www.wallystech.com/Network_Card/DR9074E-Qualcomm-QCN9074-QCN9024-WiFi6-and-WiFi6E-4x4-MU-MIMO-Dual-Band-WiFi-Module-MiniPCIe.html
BY:Wallys Communications (Suzhou ) Co., LTD
EMAIL:sales3@wallystech.com
