查看: 2639|回复: 0
Wallys//IPQ8072/IPQ8074/IPQ8072A/IPQ8074A/HighPower 802.11ax
发表于 2022-12-2 14:45:57 | 显示全部楼层 |阅读模式
IPQ8074 is Qualcomm's first WiFi6 networking solution designed to meet the growing demands of increasingly crowded and dense Wi-Fi environments. It offers the best configuration to bring unprecedented capacity and coverage to Wi-Fi networks and supports several unique features to ensure the best Wi-Fi performance for all types of applications. IPQ8074A compared with IPQ8074, IPQ8074A has added the MU-MIMO Uplink, OFDMA-UL, MU-RTS (Multi-User Request To Send), Preamble Finally, Spatial Reuse (OBSS PD). Maximizing the payload data rate by improving efficiency reduces contention between STAs and improves channel utilization. This shows that IPQ8074A can have more stable and higher wireless data rate, anti-interference ability is also more excellent.
DR8074A(HK01)
Features
■ Qualcomm Atheros IPQ8074A AR Quad Core CPU
■ On-board 5GHz radio, up to 4804Mbps physical data rate 32MB NOR Flash, 256MB NAND Flash
■ On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ Support 11ax TX Beamforming
■ Support 11ac/ax MU-MIMO DL and UL
■ Support OFDMA DL and UL
■ Tri-band support with 5G SBS (4x4/5GHz + 4x4/5GHz) + 4x4/2.4GHz
■ Supports Dynamic Frequency Selection (DFS)
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Operating Temperature Range
    -20 to +70
    oC
    Storage Temperature Range
    -40 to +90
    oC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8074A 2.2GHz CPU
    CPU Frequency
    Derived from Qualcomm Atheros AP.HK01
    System Memory
    1GB (2x 512MB) DDR3L 32-bit interface
    Frequency Range
    2.412GHz to 2.472GHz, 5.150GHz to 5.825GHz
    Modulation Techniques
    OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
    NGFF Slot for 5G Module
    M.2 (NGFF) “B Key” Socket with PCIe 3.0 interface
    Optional Onboard Modules
    Supports 1x BT module,1x ZigBee module,1x Touch pad connector,1x Audio header,1x LCD display header
    Flash
    NOR Flash: 32MB NAND Flash: 256MB
    eMMC: 8GB
    Wireless
    On-board 4x4 2.4GHz MU-MIMO 802.11b/g/n/ax, max TBDdBm per chain
    On-board 2x(4x4) or 8x8 5GHz MU-MIMO 802.11a/802.11n/802.11ac/802.11ax, max TBDdBm per chain
    12x U.FL connectors
    Reset Buttons
    2x Hardware reset button, 1x WPS reset button
    DC Jack Input
    1x DC Jack Connector: 12V, 5A
    Interface
    5x Gigabit Ethernet (1GbE) LAN/WAN RJ45 Port (Auto MDI-X)
    1x 10Gigabit Ethernet (10GbE) LAN/WAN RJ45 Port (Auto MDI-X) 1x SFP+ Port
    2x USB 3.0 Port
    1x Serial Port 12 Pin Connector 1x JTAG 20 Pin Connector
    1x micro SD Card Socket
    1x M.2 Slot
    LED
    13x LED indicators, 2 additional LED on Ethernet port
    Power Consumption
    TBD
Wallys Communications (Suzhou ) Co., LTD) is a professional supplier of wireless communication products and has a complete industrial chain in China.
Its main business is to design and manufacture the latest industrial wireless products, such as router boards, network interface cards, access points, etc., with a wide range of industrial applications.Our biggest advantage is our independent research and development ability.We can provide one-stop customized solutions according to customers' detailed requirements.
Recently, our company launched many new products, such as Antenna (DRA24126ESBE),DR6018-S,DR6018C V01,DR8072 V01,DR40X9,DR9074-6E,DR9074-5G and so on.
For more products please visit: https://www.wallystech.com/product.html
Follow us in the Youtube: https://www.youtube.com/channel/UClmu7LBz_OWxe2VckkQr3tw
