查看: 2586|回复: 0
Wallys/ industrial mini pcie card/2x 2 5G /High power Radio card
发表于 2022-12-2 14:52:44 | 显示全部楼层 |阅读模式
DR882
https://www.wallystech.com/Network_Card/DR882-Qualcomm-Atheros-QCA9882-2T2R-MIMO-802.11ac-Mini-PCIe-Wi-Fi-Module-5G-high-power.html
Wallys Communications (Suzhou ) Co., LTD(http://www.wallystech.com) is a professional supplier of wireless communication products and has a complete industrial chain in China. Our biggest advantage is our independent research and development ability, which can support you in the later period.
IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ8072/IPQ8074/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882 /AR9582/AR9531/AR9344/AR9531
BY:Wallys Communications (Suzhou ) Co., LTD
wifi6 router/network card
wifi 6E
WiFi 6
802.11ax/802.11ac
wireless solutions
Dipole/ panel //Dual Polarization Enclosure /Smart /omni /Antenna
Wireless Access Point/Point to Point /
Featuring with industrial-grade Atheros’s QCA9882 chipset
Integrated with 2x 2 5G high power Radio Card
4.940GHz to 5.825GHz Frequency Range
2 x 5G MMCX Connectors
20MHz/40MHz/80MHz Bandwidth
Support 802. 11AC/AN
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
DR882 is an industrial grade Atheros QCA9882 chipset, which is integrated with two 2.5G high power Radio Card. The frequency range covers the 4.940GHz to 5.825GHz band. It supports 802.11AC/AN and has a 20MHz/40MHz/80MHz bandwidth.
It is RoHS compliant, ensuring a high level protection of human health and the environment from risks that can be posed by chemicals.
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    3.3V(MINIPCIE)
    V
    Operating Temperature Range
    -40 to +60
    oC
    Storage Temperature Range
    -65 to +105
    oC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    QCA9882
    Antenna Connector
    2 x 5G MMCX connectors
    ROHS Compliance
    YES
    Dimension
    50mm x 30mm x 16mm
