查看: 3304|回复: 0
AP1230 LDO 低压差线性稳压器
发表于 2022-12-26 10:56:19 | 显示全部楼层 |阅读模式
AP1230 series are highly precise, low power consumption, high voltage, positive voltage regulators manufactured using CMOS and laser trimming technologies .The series provides large currents with a significantly small dropout voltage. The series is compatible with low ESR ceramic capacitors .The current limiter’s foldback circuit also operates as a short protect for the output current limiter and the output pin.
Features
Highly Accurate:±2%
Output voltage range:1.5V~5.0V ( selectable in 0.1V steps)
Low power consumption:8uA(TYP.)
Large output current:300mA (VIN=4.3V,VOUT=3.3V)
Input voltage: up to 6 V
Excellent Input Stability
Be available to regulator and reference voltage
&#8203ackages:SOT23-3,SOT89-3,SOT23,TO-92
Typical Application
Battery powered equipment
Communication tools
Mobile phones
Portable games
Portable AV systems
Cameras, Video systems
​Reference voltage sources
