查看: 1600|回复: 0
[其他] Wallys/mini pcie QCA9880/QCA9882 2.4G/5G Dual band support DR40x9 IPQ4019 rou...
发表于 2023-2-7 15:40:54 | 显示全部楼层 |阅读模式
Wallys/mini pcie QCA9880/QCA9882 2.4G/5G Dual band support DR40x9 IPQ4019 routerboard
Qualcomm-Atheros QCA9880 chipset
2.4GHz max 26dBm & 5GHz max 25dBm output power
IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n
3x3 MIMO Technology, up to 1.3Gbps
Mini PCI Express edge connector
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio
Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Supports Dynamic Frequency Selection (DFS)
FCC,CE and IC Certification
Symbol
Parameter
Chipset
QCA9880
Host Interface
Mini PCI Express 1.1 Standard
Antenna Connector
3 x UF.L
Frequency Range
2.4GHz: 2.412GHz to 2.472GHz
5GHz: 4.920GHz to 5.825GHz
Operating Voltage
3.3V DC
Power Consumption
5W(Max)
Modulation Techniques
OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM
Environmental Temperature
Operating: -40°C to 70°C, Storage: -40°C to 90°C
Environmental Humidity, non-condensing
Operating: 5% to 95%, Storage: Max. 90%
ROHS Compliance
YES
Dimensions (W×H×D)
30.0mm × 50.9mm × 3.2mm
  Version
Version
CPU
Feature
DR900VX
QCA9880
DR900VX-i
QCA9890
Operation Temp. Up to 85°
DR900VX-4.9
QCA9880
Support 4.9G
Wallys  has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.
Skype/EMAIL/Teams:sales@wallystech.com
WEB:https://www.wallystech.com/
