查看: 1903|回复: 2
求助场效应管的跨导怎么设置
发表于 2023-2-15 07:23:40 | 显示全部楼层 |阅读模式
发表于 2023-2-15 07:24:15 | 显示全部楼层
*      Model Generated by MODPEX     *
*Copyright(c) Symmetry Design Systems*
*         All Rights Reserved        *
*    UNPUBLISHED LICENSED SOFTWARE   *
*   Contains Proprietary Information *
*      Which is The Property of      *
*     SYMMETRY OR ITS LICENSORS      *
*Commercial Use or Resale Restricted *
*   by Symmetry License Agreement    *
* Model generated on Sep  8, 97
* MODEL FORMAT: SPICE3
* Symmetry POWER MOS Model (Version 1.0)
* External Node Designations
* Node 1 -> Drain
* Node 2 -> Gate
* Node 3 -> Source
M1 9 7 8 8 MM L=100u W=100u
* Default values used in MM:
* The voltage-dependent capacitances are
* not included. Other default values are:
*   RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0
.MODEL MM NMOS LEVEL=1 IS=1e-32
+VTO=2 LAMBDA=0 KP=0.0225
+CGSO=3.20048e-07 CGDO=1e-11
RS 8 3 0.676246
D1 3 1 MD
.MODEL MD D IS=5e-09 RS=0.01 N=1 BV=35
+IBV=10 EG=1.11 XTI=3 TT=0
+CJO=6.90899e-11 VJ=3.05405 M=0.587029 FC=0.5
RDS 3 1 6e+06
RD 9 1 0.0001
RG 2 7 6.45968
D2 4 5 MD1
* Default values used in MD1:
*   RS=0 EG=1.11 XTI=3.0 TT=0
*   BV=infinite IBV=1mA
.MODEL MD1 D IS=1e-32 N=50
+CJO=6.53908e-11 VJ=1.18116 M=0.716358 FC=1e-08
D3 0 5 MD2
* Default values used in MD2:
*   EG=1.11 XTI=3.0 TT=0 CJO=0
.MODEL MD2 D IS=1e-10 N=0.4 RS=3e-06
RL 5 10 1
FI2 7 9 VFI2 -1
VFI2 4 0 0
EV16 10 0 9 7 1
CAP 11 10 6.53908e-11
FI1 7 9 VFI1 -1
VFI1 11 6 0
RCAP 6 10 1
D4 0 6 MD3
* Default values used in MD3:
*   RS=0 BV=infinite IBV=1mA
.MODEL MD3 D IS=1e-10 N=0.4
官网认证
活跃会员热心会员推广达人优秀版主
发表于 2023-2-15 07:24:35 | 显示全部楼层
球球大佬帮忙
