查看: 2492|回复: 2
有大佬知道quartus18.1的lite版本能用opecl吗
发表于 2023-2-25 07:33:13 | 显示全部楼层 |阅读模式
联盟顾问
发表于 2023-2-25 07:33:45 | 显示全部楼层
Error (281039): Finished parallel synthesis of 1 partition(s).  1 partitions did not finish parallel synthesis because there were errorsError: Quartus Prime Analysis & Synthesis was unsuccessful. 2 errors, 514 warningsError (293001): Quartus Prime Full Compilation was unsuccessful. 4 errors, 514 warningsError: Flow compile (for project C:/Users/code/opencl/helloworld/top) was not successfulError: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run 网页链接 (23031): Evaluation of Tcl script i:/intelfpga_lite/18.1/quartus/common/tcl/internal/网页链接 unsuccessfulError: Quartus Prime Shell was unsuccessful. 11 errors, 514 warningsError: Compiler Error, not able to generate hardware
联盟顾问
发表于 2023-2-25 07:34:17 | 显示全部楼层
intel 官方类似报错解释是,clean project,编译生成的中间文件有问题,需要清除后重新编译
