查看: 3368|回复: 13
matlab2014b for mac,苹果系统matlab2014b安装方法[补充]
发表于 2023-3-16 07:33:01 | 显示全部楼层 |阅读模式
原帖http://tieba.b
matlab2014b for mac,苹果系统matlab2014b安装方法[补充]-1.jpg aidu.com/p/
3531626991?pn=1
This is the original topic I found for the instruction to install the matlab2014b for mac,
但是原帖说的还不够“傻瓜”
but it turned out to be not foolproof enough, anyway.
所以想给大家写个傻瓜安装方法,会特别强调一些容易误解的地方,并且加了一些自己拙劣的英文翻译(万一外国人看了呢)
Now I will rewrite the instruction in a more foolproof way, concentrating more on  details and some confusing, misleading parts.
第一步:
下载原帖中的资源,都解压出来,到自己的苹果电脑上。一个是安装文件,一个是破解文件,都解压到电脑上哦,可以放桌面。
Step 1:
Download the resources in the topic above and unzip both of them to your PC(PS: better to unzip them on your desktop, thus you can find them easily). The resources includes a installing file and a crack file.
第二步:
把破解文件中的install.jar覆盖到安装文件夹里的java/jar中
Step 2:
Copy and replace the "install.jar" in the crack file to "java/jar" in the installing file.
第三步:
点击安装文件夹根目录里面有个叫“install”的黑色exec文件,就能开始安装了
选择文件密钥安装,输入密钥29797-39064-48306-32452
之后基本上一直下一步下一步,直到安装完成
Step 3:
Click the "install" in the installing file to start the install process. DO NOT click the "installForMacOSX"!
Choose to enter the key, then use the key 29797-39064-48306-32452 while clicking "next" all the way until finishing the install.
第四步:
安装完成后它会自动下一步说要激活,激活选不联网手动激活,激活文件选破解文件里的“license.lic"就可以完成破解了。
Step 4:
To activate the Matlab, choose not to connect the Internet and activate manually, use the “license.lic" in the crack file for your activation license.
第五步:
替换一个文件就大功告成了,把破解文件里的“libmwservices.dylib"覆盖到安装好的matlab文件中/bin/maci64里,注意这里有人把这个文件放到安装文件的/bin/maci64目录下了,这是不对的,还有人说matlab文件在哪里。。不出意外在application里,要开打就右键那个matlab图标选择显示包内容。
Copy and replace the "libmwservices.dylib" in the crack file to "/bin/maci64" in the matlab you just installed. PAY ATTENTION that the installing file also has a  "/bin/maci64" file, DO NOT put there.
发表于 2023-3-16 07:33:36 | 显示全部楼层
原帖中的吧友遇到的错误
Q:install.jar双击之后,就这样,是什么问题?
A:这是win系统把,而且点install.jar干嘛说了点击“install”的黑色exec文件开始安装
发表于 2023-3-16 07:34:32 | 显示全部楼层
Q:为什么error-8,替换后还是出现?@公子王庆  @_kelly_璐  @zhangrong00715
A:很有可能替换了的是安装文件里的,这个dylib要复制到安装好的matlab里,因为它们都有个bin maci64 的目录所以可能误解
发表于 2023-3-16 07:34:44 | 显示全部楼层
错误同第一种
@耀_Vincent
@齐天丶大圣
发表于 2023-3-16 07:35:01 | 显示全部楼层
楼主,请问我替换过install.jar文件后,进入安装文件夹点击哪个安装呢? 点INSTALL会自动跳出文本文件--
A:我也不知道为什么,点那个install明明就可以了,可能是打开方式问题
发表于 2023-3-16 07:35:55 | 显示全部楼层
A:这个错误我在装2014a的时候出现过,不过现在我给的资源是2014b应该没问题
发表于 2023-3-16 07:36:01 | 显示全部楼层
A:这个就是少了step 5的正确替换的错误
发表于 2023-3-16 07:36:34 | 显示全部楼层
若还有其他问题 我也不会解答了= =
这是我的极限了
发表于 2023-3-16 07:37:18 | 显示全部楼层
用原贴吧文件重新安装中  希望顺利
发表于 2023-3-16 07:37:46 | 显示全部楼层
