发表于 2023-3-22 20:56:14
显示全部楼层
OldHandle = findobj('Type','figure','Tag','FireWork');if ishandle(OldHandle) close(OldHandle);end% 图形窗口初始化 fig = figure('units','normalized','position',[0.1 0.1 0.8 0.8],... 'menubar','none','name','烟花满天飞',... 'numbertitle','off','color',[0 0 0],'tag','FireWork');% 烟花炸开前的初始位置h0 = line(0,0,0,'marker','.',... 'markersize',18,... 'MarkerEdgeColor',[1 1 1],... 'MarkerFaceColor',[1 1 1],... 'EraseMode','xor',... 'color',[0 0 0]);% 设置坐标系显示属性axis equalaxis([-50 50 -50 50 0 100]) axis offview(-42,22)% 设置参数 rate = 1:-0.01:0;% 颜色衰减率v0 = 45; % 烟花头初始速度g = -9.8; % 重力加速度 usedtime = -v0/g; % 烟花头爆炸前所经历时间 zs = v0*usedtime+0.5*g*usedtime^2; %烟花头爆炸前达到的最高高度 theta = rand(250,1)*2*pi; % 各粒子速度的方位角 phi = rand(250,1)*2*pi-pi; % 各粒子速度的仰角 age = 20; % 粒子生存期 % 常用颜色矩阵 colormat = [1.0 0.5 0.5 1.0 0.75 0.5 1.0 1.0 0.5 0.75 1.0 0.5 0.5 1.0 0.5 0.5 1.0 0.75 0.5 1.0 1.0 0.5 0.75 1.0 0.5 0.5 1.0 0.75 0.5 1.0 1.0 0.5 1.0 1.0 0.5 0.75]; % 随机产生各粒子对应的颜色序号 colorid = randsample(12,250,true); % 粒子对应的颜色矩阵 colormat = colormat(colorid,:); % 粒子颜色与背景色(夜色)的距离 colordist = sqrt(sum(colormat.^2,2)); v1 = 20; % 粒子的初始速度 k = 1; % 颜色衰减率初始序号 timerA = timer('TimerFcn',@TimerFcnA,... 'executionmode','fixedspacing','Period',0.001); start(timerA); h = getappdata(gcf,'HandleParticle'); timerB = timer('TimerFcn',{@TimerFcnB},... 'executionmode','fixedspacing','period',0.001); %-------------------------------------------------------------------------- % 定时器回调函数(烟花头) %-------------------------------------------------------------------------- function TimerFcnA(timerA,event) ta = get(timerA,'TasksExecuted')*0.1; if ta <= usedtime z = v0*ta+0.5*g*ta^2; set(h0,'zdata',z,... 'MarkerEdgeColor',[1 1 1],... 'MarkerFaceColor',[1 1 1]) drawnow %pause(0.01) else delete(h0) stop(timerA); x0 = zeros(2,250); y0 = zeros(2,250); z0 = zs*ones(2,250); h = line(x0,y0,z0,'marker','h',... 'markersize',12,... 'MarkerEdgeColor',[1 1 1],... 'MarkerFaceColor',[1 1 1],... 'EraseMode' , 'xor',... 'color',[0 0 0]); setappdata(gcf,'HandleParticle',h); start(timerB); end end |
