查看: 1257|回复: 6
这是肿么了?Invalid MEX-file 找不到指定的模块。
联盟顾问
发表于 2023-4-8 20:25:44 | 显示全部楼层 |阅读模式
Invalid MEX-file 'D:\Program Files\MATLAB\R2013a\mcr\toolbox\matlab\imagesci\private\rjpg8c.mexw64': 找不到指定的模块。
Error in readjpg (line 12)
Error in imread (line 416)
Error in test (line 4)
Unable to print provided exception.
Caused by:
    Errors occurred while loading the Settings files.
    Details: D:\Program Files\MATLAB\R2013a\toolbox\matlab\matlab.settingsInternal Error: Failed to find SAX plugin.
    C:\Users\Mention\AppData\Local\Temp\Mention\mcrCache8.1\myFuct0\.matlab\matlab.settingsInternal Error: Failed to find SAX plugin.
    There is no Settings files associated with this product node: matlab. The Settings files may be deleted after MATLAB started up. Please restart MATLAB to fully solve this issue.
发表于 2023-4-8 20:25:51 | 显示全部楼层
别沉!!!!!!!
发表于 2023-4-8 20:26:50 | 显示全部楼层
别沉!!!!!!!!!!!
发表于 2023-4-8 20:27:11 | 显示全部楼层
别沉!!!!!!!
发表于 2023-4-8 20:27:52 | 显示全部楼层
俺也遇到这个问题了,再那个文件夹下,的确也没找到这个文件,楼主怎么解的
发表于 2023-4-8 20:28:07 | 显示全部楼层
我也遇到了类似的错误,主控程序有误
发表于 2023-4-8 20:28:28 | 显示全部楼层
我也遇到类似问题
