查看: 2995|回复: 10
xilinx USB Cable 找不到!
官网认证
活跃会员热心会员推广达人优秀版主
发表于 2023-5-16 10:54:32 | 显示全部楼层 |阅读模式
驱动安装结束,如下图,下载器指示正常为绿灯,
* e8 W0 s  M6 {. q
% [( A9 T0 J# F
: @( O, X: Q+ |1 `/ w
. [* h1 F6 [+ d' J
# Z* V" D. }3 Q3 O% @: \  G/ r& \, y" c$ d* s8 {
进入IMPACT界面时,点击PROGRAM出现如下错误:9 ], |1 Y4 v( f
7 I6 K- w4 o& X1 P6 S. |0 L
! F3 `  ^% b: R2 \GUI --- Auto connect to cable...- [& q) s$ T! u. l% W( ~
INFO:iMPACT - Digilent Plugin: Plugin Version: 2.4.48 w2 \) s( Y. ~0 g  U- F
INFO:iMPACT - Digilent Plugin: no JTAG device was found.
: D6 O7 \: l) g3 \$ M! v/ o! sAutoDetecting cable. Please wait.
0 u8 y* B2 q6 x" H) e*** WARNING ***: When port is set to auto detect mode, cable speed is set to default 6 MHz regardless of explicit arguments supplied for setting the baud rates
; }' b. y# [" S9 i1 j1 V, fPROGRESS_START - Starting Operation.
( l& [( n0 m, ?6 aConnecting to cable (Usb Port - USB21).
$ g8 M5 h% |: ^$ S4 d8 fChecking cable driver.
, Y# g' k4 A8 Q# R0 g Source driver files not found.1 G/ [9 D! K6 \" m# R
The Platform Cable USB is not detected. Please connect a cable.If a cable is connected, please disconnect
) K7 z  z' r0 j4 a/ ~$ D+ Kand reconnect to the usb port, follow the instructions in the 'Found New Hardware Wizard', then retry
' [* f& z4 `) H- uthe Cable Setup operation.
! N$ A* t" E# e/ [Cable connection failed.
; O3 O* I4 H7 w) u( EConnecting to cable (Parallel Port - LPT1).. x. D% s& C- F
) j5 r% T) u3 P3 {Your driver installation is not complete. Please re-run your application or run- O) t; _. Q$ f
install_drivers.exe from the ISE installation area as an Administrator to complete the driver installation.! {+ `7 A0 [5 u8 z1 X
Service using windrvr6.sys : SYSTEM\CurrentControlSet\Services\WinDriver6.# z2 [6 v# _% y
ImagePath = \SystemRoot\system32\drivers\windrvr6.sys.4 `$ @8 y% K$ v, `) P
Start = 3.$ A9 C  a. l0 w' A: C6 t
ErrorControl = 1.
9 s. k, f6 P$ v- n. r. g$ ? Type=1.
; _: H3 ^" ~- z- V0 m1 TCable connection failed.
" s* ]  T0 W4 RConnecting to cable (Parallel Port - LPT2).+ A/ a7 t. z0 k$ c2 s; m
* b  z' o$ i: V' OYour driver installation is not complete. Please re-run your application or run$ ?4 l, n' b$ }: i  k- \
! C8 e5 g* x1 ~, z+ `Service using windrvr6.sys : SYSTEM\CurrentControlSet\Services\WinDriver6.: w' F. w  Y, U3 k  }
' c4 u5 G- R! o0 B Start = 3.
/ \9 ^: o1 x6 n1 t+ Y ErrorControl = 1.' x5 ]3 E! v  p1 v$ q, j
Type=1.
& L2 ?, L* d/ ACable connection failed.# t+ O0 `# h5 s/ T- T2 b! ]
Connecting to cable (Parallel Port - LPT3).
0 a+ c8 @& X6 H" ~7 _% B" J, NChecking cable driver.5 d. F/ U! F& z! J4 N8 b7 m( u, U
  c: \0 E  O5 V% v7 d6 R% Linstall_drivers.exe from the ISE installation area as an Administrator to complete the driver installation.
1 @2 K' C' w; J8 \$ w) V, dService using windrvr6.sys : SYSTEM\CurrentControlSet\Services\WinDriver6.3 ]7 B% ~2 e$ i
2 I; b$ o0 U& ]! v. V Start = 3.9 f1 r0 K- |4 ]% C5 z7 x- E
ErrorControl = 1.
# \/ V. \0 d( G( W5 \ Type=1.
6 @4 S: |  G* F& A' A" v2 RCable connection failed.
- F) N, f1 S8 q1 z0 _- [7 @Connecting to cable (Parallel Port - LPT4).7 I. s) X2 V( A9 O# C4 m
Checking cable driver.3 c. _& I+ n% Y" L; @# n
Your driver installation is not complete. Please re-run your application or run5 R; ^2 Y5 I4 C
install_drivers.exe from the ISE installation area as an Administrator to complete the driver installation.% l8 S( H' m* K7 v6 |
Service using windrvr6.sys : SYSTEM\CurrentControlSet\Services\WinDriver6./ f/ m' U& c7 U( i. h: f# @
ImagePath = \SystemRoot\system32\drivers\windrvr6.sys.; b. F! l6 a1 |5 @" y
Start = 3.( \" ^  j) W- S& [
ErrorControl = 1.( Y( H! S' }; c( P
Type=1.- g. Z/ n' F5 N
Cable connection failed.+ s" }) |3 X+ U& S$ \# A
PROGRESS_END - End Operation.2 j! V' T% G* H3 u( p4 w6 i* R
Elapsed time =      2 sec.
3 d# p6 B& {) q6 m9 pCable autodetection failed.
: q7 `8 h2 g3 S  r& o/ a; t% b0 Z$ b) bWARNING:iMPACT:923 - Can not find cable, check cable setup !$ V: c, K( E( j& R
; ~, D' P, B, g3 e  D
- {3 N2 p) I3 w# p+ C$ C0 B
各位大神解围,不胜感激!
发表于 2023-5-16 10:55:18 | 显示全部楼层
发表于 2023-5-16 10:55:52 | 显示全部楼层
https://blog.csdn.net/qq_36775035/article/details/80714563
发表于 2023-5-16 10:56:35 | 显示全部楼层
经过了6天的摸索,终于成功了,祈祷,阿门!
发表于 2023-5-16 10:57:23 | 显示全部楼层
楼主楼主,能问一下你是怎么解决的吗
联盟顾问
发表于 2023-5-16 10:57:30 | 显示全部楼层
具体怎么解决,我跟你遇到的问题一模一样,好些天都没进展,麻烦你指导一下。
8 u! _) a; T3 q4 r
官网认证
活跃会员热心会员推广达人优秀版主
发表于 2023-5-16 10:57:36 | 显示全部楼层
重新安装驱动
发表于 2023-5-16 10:57:41 | 显示全部楼层
你好,我遇到了同样的问题,也重新装了ise自带的驱动,仿真器的指示灯显示正常(电路板不上电为橘黄色,上电是绿色),但是还是出现 你上述的问题。Can not find cable, check cable setup !6 [/ c# F1 E" N; \. J' S
可否联系一下;e-mail:144605975@qq.com
发表于 2023-5-16 10:58:02 | 显示全部楼层
我遇到的问题是打开cable set界面会闪退
  D: Q" ]1 y) I* R- m0 B
发表于 2023-5-22 11:25:35 | 显示全部楼层
77777777777777777777777
