查看: 1108|回复: 0
IPQ8072|XGS-PON|Dual Band 10GbE Wifi6 Industrial SBC DR8072V01
发表于 2023-7-18 13:46:47 | 显示全部楼层 |阅读模式
What is XGS-PON?
What is XGS-PON? XGS-PON is an updated standard for Passive Optical Networks (PON) that can support higher speed 10 Gbps asymmetrical data transfer and is part of the family of standards known as Gigabit-capable PON, or G-PON. G-PON stands for Gigabit PON or 1 Gigabit PON.
XGS-PON is an updated standard for Passive Optical Networks (PON) that enables high-speed data transfer of up to 10 Gbps in an asymmetrical manner. It belongs to the family of Gigabit-capable PON (G-PON) standards, which are designed to provide gigabit-level broadband services.
In recent years, XGS-PON has become the preferred technology for operators in North America. The region has experienced significant growth in the adoption of PON equipment for residential fiber broadband services. From 2019 to 2022, the shipment of XGS-PON OLT ports in North America has increased by an impressive 2231%.
DR8072V01----- A Routerboard with 10G Ethernet port 10G SFP
Wallys have a board DR8072V01 which with 10G Ethernet Port, could support XGS-PON project.The DR8072V01 equip with the Qualcomm Atheros IPQ8072A AR Quad Core CPU, which features on-board 5GHz radio, up to 2475 Mbps physical data rate, and on-board 2.4GHz radio, up to 1147Mbps physical data rate. It has 8 MB NOR Flash, 256MB NAND Flash (NAND Flash can be up to 1GB as optional), support 11ax TX Beamforming, support 11ac/ax MU-MIMO DL and UL, supports Dynamic Frequency Selection (DFS), DDR 1GB DDR3L (support DDR3L can be up to 2GB as optional) M.2 connector support QCN9074.
Hardware specification as below:
SoCualcomm Atheros IPQ8072A quad-core Arm Cortex-A53 @ 2.2 GHz part of Qualcomm Networking Pro 1200 Platform
System Memory:512MB DDR4 2400MHz 16-bit interface (option up to to 2GB RAM)
Storage:8MB NOR flash, 256MB NAND flash
Networking:
Wireless:
On-board 4×4 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 17dBm per chain, up to 1147Mbps
On-board 4×4 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 17dBm per chain, up to 2475Mbps
Frequencies:2.412 to 2.472 GHz, and 5. 150 to 5 .825 GHz
Modulation Techniques OFDMA, BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
8x u.FL antenna connectors
Wired:
1x 10Gbps Ethernet RJ45 port
1x 10Gbps SFP cage
4x Gigabit Ethernet RJ45 ports
USB:2x USB 3.0 ports
Expansion:1x  MiniPCIe Slot with PCIe 3.0
Debugging:20-pin JTAG connector, 4-pin serial connector
Misc:1x software reset button, 2x RGB LED
Power Supply:12V via DC jack
Temperature Range:-20ºC to 70ºC; storage: -40ºC to 90ºC
Click below the link for more information about this router board.
https://www.wallystech.com/Routerboard/DR8072V01-wifi6-Qualcomm-IPQ8072A-4T4R-support-OpenWRT-802.11AX-supporting-10GE-port-10G-SFP.html
Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook.
With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market.
Visit our website:https://www.wallystech.com/
