查看: 1452|回复: 0
IPQ5018|WIFI6|DR5018 vs DR5018M what's the difference?
发表于 2023-7-25 11:27:05 | 显示全部楼层 |阅读模式
Qualcomm IPQ5018 Chip
IPQ5018 is an advanced embedded processor developed by Qualcomm, designed specifically for Wi-Fi network applications. It boasts a powerful quad-core ARM Cortex-A53 processor running at up to 1.0GHz, delivering exceptional computing and processing capabilities to handle diverse data and applications effectively.
One of the primary advantages of the IPQ5018 chip is its high-speed network connectivity. It supports multiple Wi-Fi standards, including 802.11ac, 802.11ax, and is backward compatible with 802.11a/b/g/n. This enables seamless dual-band Wi-Fi connectivity and ensures fast network transmission speeds.
Security is a top priority for the IPQ5018 chip. It incorporates various security features and encryption algorithms, such as WPA3, AES encryption, and TLS/SSL, guaranteeing the safety and reliability of network data transmission, protecting against potential threats.
Flexibility is another key strength of the IPQ5018 chip. It supports a wide range of peripheral interfaces, including USB, PCIe, allowing easy connectivity and communication with other devices. Furthermore, it is compatible with multiple operating systems, such as Linux and Android, offering exceptional flexibility, scalability, and reliability for diverse applications.
In addition to its high-performance capabilities, the IPQ5018 chip is engineered for low power consumption and heat generation. Leveraging advanced manufacturing technology and energy-saving design, it is ideally suited for various embedded application scenarios, including smart homes, Internet of Things (IoT), and smart manufacturing.
Overall, the IPQ5018 stands as a cutting-edge embedded processor, combining high performance, secure network connectivity, flexibility, and energy efficiency, making it a top choice for Wi-Fi network applications in modern technological landscapes.
Wallys has recently launched a new WiFi 6 SoC, the DR5018M, which builds upon the performance of the IPQ5018 while offering a smaller form factor. When combined with a customized baseboard, it becomes suitable for a wider range of applications. The DR5018M allows for customized selection of Ethernet ports, making it a more flexible choice for hardware used in IIOT, smart cities, and smart ports, among other applications. The DR5018M shares similarities with the DR5018, and below are some compatible configurations:
Key feature of DR5018:
Dual-core ARM 64bit A53@1.0GHz Processor
512MB DDRL3L System Memory
4MB NOR Flash, 128MB NAND Flash
2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate
Support BT5.1
M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;
M.2 Card Slot for QCN9074 WIFI 6E Card
Support Openwifi
Low Cost WIFI6E QCN6122 Solution DR6122
DR6122-6E based on QCN6122 Chipset is an enterprise wireless module integrated with
2 x 2 MU- MIMO 6 GHz Single Band Wireless Module designed specifically to provide users withmobile access to high- bandwidth video streaming, voice, and data transmission for office andchallenging RF environment in factories, warehouses establishment.
Features
■ Qualcomm Atheros QCN6122
■ 6GHz, max 23dBm per chain, up to 2402Mbps
■ Single Band 6GHz 2x2 WiFi 6E (802. 11ax)
■ 2 spatial streams (2SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
Low Cost WIFI6 5G QCN6102 Solution
DR5018:Support 2.412GHz~2.472Ghz
DR5018+DR6102-5G:Support 2.412GHz~2.472Ghz-5.180GHz ~5.825Ghz
DR5018+DR6122-6E:Support 2.412GHz~2.472Ghz-5.925GHz~7.125GHz
Higher Performance WIFI6 6E QCN9074-6E Solution
Features
Qualcomm Atheros QCN9074
6GHz, max 23dBm per chain, up to 4949Mbps
Single Band 6GHz 4x4 WiFi 6E (802.11ax)
4 spatial streams (4SS)
M.2 E Key Interface
Higher Performance WIFI6 5G QCN9074-5G Solution
Features
5GHz, max 23dBm per chain, up to 4949Mbps
Single Band 5GHz 4x4 WiFi 6 (802.11ax)
M.2 E Key Interface
Supports Dynamic Frequency Selection (DFS)
For more customized WiFi solutions, please contact Wallys sales team for further inquiries. They have a dedicated team of professionals, including software and hardware engineers, to support your projects and provide a one-stop service from hardware design to mass production. Wallys offers existing industrial WiFi 5, WiFi 6, and WiFi 7 solutions.
Email:Sales1@wallystech.com
Website:https://www.wallystech.com/
