查看: 952|回复: 0
DR6018|IPQ6010 IPQ6018 WiFi6 2X2 QSDK OpenWiFi Cloud AP AC Customizable Solution
发表于 2023-9-18 13:09:34 | 显示全部楼层 |阅读模式
WiFi 6,also known as 802.11ax, represents the latest generation of wireless networking technology. It builds upon the foundation established by its predecessor, WiFi 5 (802.11ac), and brings several significant improvements to the table.
What is OpenWiFi?
OpenWiFi: An industry movement for accelerating Wi-Fi infrastructure innovation.
OpenWiFi is an open sourced, community-developed, disaggregated Wi-Fi software system. The system includes a cloud controller SDK and an Enterprise-grade Access Point (AP) firmware, designed and validated to work seamlessly together.
The Benefits of OpenWiFi
TIP OpenWiFi significantly improves the business case for Wi-Fi through:
Lower R&D cost to develop enterprise-grade Wi-Fi solutions
OpenWiFi’s advanced feature set, including Wi-Fi 6, Passpoint and OpenRoaming® capabilities, enable existing and new suppliers to offer Enterprise-grade Wi-Fi products with less development effort
Cloud software OEMs and hardware ODMs are able to reduce R&D expense when by building their solutions on top OpenWiFi’s robust, single codebase of common Wi-Fi “plumbing”
Accelerated, open innovation
OpenWiFi’s common control, data and management layers allow suppliers and service providers to focus their development and integration efforts on service innovation rather than inventing Wi-Fi “plumbing”
The cloud controller SDK provides open north-bound APIs, so over-the-top Wi-Fi applications can be integrated once and then be used with multiple vendor solutions, saving integration costs and reducing time to market
Favorable economics for Service Providers and Enterprises
OpenWiFi’s combination of deployment savings (CAPEX) and automation-driven operational savings (OPEX) brings significant reduction in Total Cost of Ownership (TCO) over current proprietary solutions
OpenWiFi’s diverse multi-vendor selection of cloud controllers and access points brings service providers choice and flexibility in enterprise grade Wi-Fi infra
Support WiFi6 Hardware-Wallys
Wallys DR6018 is an industrial-grade,concurrent dual-band Wi-Fi6 Routerboard.
DR6018
Qualcomm-Atheros IPQ6010
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Support Openwifi
Support QSDK
Absolute Maximum Rating
Parameter
Rating
Unit
Supply Voltage
24V~48
V
Operating Temperature Range
-40 to +70
ºC
Storage Temperature Range
-45 to +105
ºC
Operating Humidity Range
5 to +95 (non-condensing)
Hardware Specifications
Symbol
Parameter
CPU
CPU Frequency
Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
SD Card Slot
1x SD Card Slot
USB /header
1x USB 2.0 Port
POE
24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack
24V power supply
LED header
FFC/FPC Connector
Serial Port
1x Serial Port 4 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
Bluetooth
optional
Nor Flash
8-32MB(normally is 8MB)
Nand Flash
256MB
DDR
1GB
Dimension
185mm x 116mm
https://www.wallystech.com/Routerboard/DR6018V4-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-supporting-5G-celluar-Modem-802-11AX-MU-MIMO-OFDMA.html
Recently, the DR6018 series routers have officially demonstrated their impressive long-distance capabilities by successfully achieving a remarkable 23 km transmission range.
Tailor your own AC+AP Solution (AP Controller) with Wallystech!
Our AC software empowers you with cross-city, cross-domain management capabilities. Customizing special functions is a breeze. Feel free to reach out to our sales team for inquiries.
Email:sales1@wallystech.com
Website:https://www.wallystech.com/
