查看: 1271|回复: 0
QCN9024 Performance|WiFi6E TriBand Card DR9074 Achieving Blazing 1.3Gbps Spee...
发表于 2023-10-19 15:28:01 | 显示全部楼层 |阅读模式
QCN9024 Performance|WiFi6E TriBand Card DR9074 Achieving Blazing 1.3Gbps Speed in 5.28GHz 80MHz BW Throughput Test
Both the QCN9074 and QCN9024 are Qualcomm chips, and Wallys has chosen this platform for the development of Tri-Band card due to its exceptional stability and superior performance.
Let me share the fascinating story of its inception. Before the advent of the remarkable DR9074 Tri-Band Network card, Wallys had already pioneered single-band network cards like the DR9074-2.4G, DR9074-5G, and DR9074-6E, each earning a reputation for top-notch performance.
Then came an intriguing request from one of our valued customers: 'The DR9074-5G and DR9074-6E deliver exceptional performance; do you have plans for a Tri-Band version of this card?' As an innovation-centric company, this question ignited a spark among our engineers.
Fuelled by passion and driven by the pursuit of excellence, our engineers toiled day and night. And voilà, Wallys proudly presents the DR9074 Tri-Band Network card, a testament to our commitment to innovation and customer satisfaction.
Today, let's delve into the performance of this network card and explore the throughput test we recently conducted.
Test Equipment:
Routers: 2 units of Wallys DR6018
Network Cards: 2 units of Wallys DR9074-TRIBAND
Feedlines: 4
PCs: 2
Test Software: IxChariot
Test Procedure:
First, insert two DR9074-TRIBAND cards into the M.2 card slots of the Wallys DR6018 routers and connect them to two PCs using Ethernet cables. Power up the equipment.
Set the modes of the two network cards to one AP (Access Point) and one STA (Station). Configure the SSID for both as "Triband." On the AP side, select the 5.28GHz frequency with an 80MHz bandwidth. Once the AP and STA establish a wireless connection, and both computers connected to the AP and STA can ping each other, open IxChariot to begin running traffic.
Test results are as follows:
*Please note that due to the limitations of the 1G network port, we were only able to achieve a speed of 1.3Mbps in this specific test. Under optimal testing conditions, speeds can reach up to 4Gbps. Stay tuned to our blog for updated test data.
If you're interested in learning more about the DR9074-Triband or have any questions, feel free to reach out to them.
Website:https://www.wallystech.com/
