IPQ9574 IPQ9554 /QCN9274 / QCN6274 limitless- speed, endless possibility, new WiFi 7
The biggest technical highlight of Wi-Fi 7 is that it supports 320MHz channels, which have never been used by previous home routers.
What's more, Wi-Fi 7 allows the use of spectrum resources from 1GHz to 7.2GHz, and focuses on compatibility with the 2.4GHz and 5GHz bands of the previous Wi-Fi standard, achieving greater theoretical bandwidth through a large spectrum surface.+
Wi-Fi 7 enables exciting new experiences and use cases
In addition to improving the performance of the apps people use today, Wi-Fi 7 will enable many new experiences. Taking cutting-edge extended reality (XR) applications as an example, they are extremely sensitive to delay, and if you can't achieve low delay, the terminal will be useless. Realistic, immersive XR experiences are supported by high-definition video with extremely high refresh rates, which require very high network speeds and bandwidth. At the same time, a large network capacity is required to support a large number of users to experience the above applications at the same time. In addition, emerging applications such as cloud gaming, social gaming and metacomes will continue to test the limits of wireless technology. For that, Wi-Fi 7 will give us plenty of performance.
As a R&D, production and design of their own brand of WiFi solution ODM/OEM, Wallys has in-depth research on WiFi protocol, from 802.11n-802.11be, won the trust of many customers, and reached a long-term cooperative relationship.
Secondly, the biggest advantage of Wallys is that it has a strong software development team and hardware design team, which can customize hardware for customers and develop software functions to better win projects!
At present, most of the WiFi7 products on the market use Qualcomm's chip IPQ9574/IPQ9554, the former is an industrial grade, the latter is a commercial grade application, the key difference is that the WiFi7 motherboard designed by IPQ9574 has 2.4G radio. The WiFi7 motherboard designed by IPQ9554 has no radio, but it can realize the demand for radio through the WiFi card, which is also a cost-saving program!
It designed the WiFi7 card chip is mainly used by Qualcomm, QCN9274/QCN6274, these two are also a difference between industrial and commercial applications, followed by the cost will be different, wallys designed the version of 4, can give customers a variety of choices to adapt to more project needs.
1. 4x4 6G
2. 4x4 5G
3. DBDC 2x2 2.4G & 2x2 5G
4. DBDC 2x2 5G & 2x2 6G
The advantages of WiFi7 are many
Higher speeds: Newer Wi-Fi standards often offer higher speeds. Wi-Fi 6 (802.11ax) has already made improvements for high-density environments and faster speeds, and Wi-Fi 7 is likely to further increase this performance.
Greater spectrum range: Wi-Fi 7 will likely offer more spectrum options outside the 6GHz band to support greater bandwidth and faster data transfer rates.
Lower latency: Updates to Wi-Fi standards often involve improvements to latency as well. Lower latency is important for real-time applications such as online games and video conferencing.
Better performance management: The new standard may introduce more advanced performance management techniques to improve the efficiency and stability of the network.
Better security: As technology evolves, new generations of Wi-Fi standards often introduce more robust security features to meet growing cyber threats.
