查看: 764|回复: 0
QCN9274 vs. QCN9024:Which Holds the Key to Tomorrow's Connectivity?
发表于 2023-12-26 10:33:46 | 显示全部楼层 |阅读模式
In the ever-evolving landscape of wireless technology, two formidable chipsets, QCN9274 and QCN9024, are at the forefront of innovation. Let's delve into the advancements they bring to life through the groundbreaking products DR9274-6G and DR9074-Triband.
# @0 D" d8 U% r1 K! i! p& R* q
DR9274-6G: QCN9274 Unleashed
Qualcomm Atheros QCN9274 for Industrial Grade
Maxim Tx power 22dBm per chain
4x4 6G MU-MIMO, up to 11530Mbps physical data rate
Support up to 4096-QAM
M.2 connector
PCI Express 3.0 Interface
This enterprise wireless module, based on the QCN9274 chipset, is a powerhouse integrated with 4x4 MU-MIMO single Band Wireless Module. Tailored for applications such as security surveillance, commercial radio coverage, and hotel wireless scenarios, it thrives in challenging RF environments. Its impressive features include a 6GHz frequency range, 4096QAM support, and a compact M.2 form factor.
DR9074-Triband: QCN9024 Redefined
Qualcomm Atheros QCN9024
Maxim 23 dBm per chain, up to 4949Mbps
Support Tri-Band 2.4GHz&5GHz&6GHz 4x4 WiFi 6E (802.11ax)
4 spatial streams (4SS)
M.2 E Key Interface
The DR9074-Triband, driven by the QCN9024 chipset, is a dual-band wireless module with Tri-Band support. Operating in the 2.4GHz, 5GHz, and 6GHz bands, it excels in security surveillance, commercial radio coverage, and more. With a data rate of up to 4949Mbps, 4 spatial streams, and an M.2 E Key Interface, it redefines the possibilities of high-bandwidth applications.
Comparative Glance: QCN9274 vs. QCN9024
While both chipsets offer industrial-grade performance, the QCN9274 focuses on the 6GHz spectrum with a staggering 11530Mbps data rate. On the other hand, the QCN9024 powers the Tri-Band DR9074, providing flexibility across 2.4GHz, 5GHz, and 6GHz.
In conclusion, the QCN9274 and QCN9024 chipsets, manifested in the DR9274-6G and DR9074-Triband, respectively, showcase the pinnacle of wireless innovation. The question remains: Which chipset will be the driving force behind your wireless future?
5 d1 {' i1 B4 s; C  O, d
