QCA9882, QCA9880, and MT7915 WiFi cards for OpenWrt:What are the difference?2 K1 @2 ~! r7 r6 u; {, F
In the realm of OpenWrt-compatible WiFi cards, selecting the right one can significantly impact your network's performance and reliability. Among the options available, the QCA9882, QCA9880, and MT7915 stand out as popular choices. In this article, we will delve into the differences between these WiFi cards to help you make an informed decision. . A9 H6 c' U9 b' i) p5 @
**QCA9882**
" I; a4 k8 l2 x1 x8 m# tThe QCA9882 WiFi card boasts a robust chipset designed to deliver exceptional performance. It supports various wireless standards, including WiFi 5 (802.11ac), ensuring compatibility with modern networks. Performance metrics such as throughput and range are commendable, making it suitable for demanding applications. QCA9882 is known for its seamless integration with OpenWrt, offering extensive configuration options and stability. While pricing may vary, it generally falls within a reasonable range, providing value for money. 5 L! I5 a' _. R
**QCA9880**
: r8 [/ B1 `0 S- K) N/ L- bSimilar to the QCA9882, the QCA9880 WiFi card features a reliable chipset optimized for high-performance networking. It also supports WiFi 5 standards, guaranteeing compatibility with modern networks. Performance metrics are commendable, although specific benchmarks may vary. QCA9880 is well-supported by OpenWrt, offering users a plethora of configuration options and stability. Pricing for the QCA9880 is competitive, making it an attractive choice for budget-conscious consumers seeking reliable performance.
8 `: R" {) x; j% h**MT7915** h! `+ n/ k+ t7 P
The MT7915 WiFi card is another contender in the OpenWrt ecosystem, boasting a chipset designed to deliver robust performance. It supports WiFi 6 (802.11ax) standards, offering enhanced throughput and efficiency compared to its predecessors. Performance metrics such as throughput and latency are impressive, catering to demanding networking requirements. While OpenWrt compatibility may vary, efforts are underway to ensure seamless integration with the platform. Pricing for the MT7915 tends to be higher compared to WiFi 5 alternatives, reflecting its advanced features and capabilities. + t2 {; _, ]( d: p5 X/ O7 c
**Comparative Analysis**
1 k7 q: V. a! q6 {0 j: t2 T% VWhen comparing these WiFi cards, several factors come into play. Performance-wise, the MT7915 holds an edge with its support for WiFi 6 standards, offering superior throughput and efficiency. However, both the QCA9882 and QCA9880 remain competitive choices, especially for users with WiFi 5 networks. In terms of OpenWrt compatibility, all three options offer varying degrees of support, with QCA9882 and QCA9880 being more established within the community.
/ r" r# s1 Q! F3 \$ C**Conclusion**
& S- e- c$ n4 x# V, b- TIn conclusion, the choice between the QCA9882, QCA9880, and MT7915 WiFi cards depends on your specific requirements and budget constraints. If you prioritize cutting-edge performance and have the budget for it, the MT7915 is an excellent option. However, for users seeking reliable performance at a more affordable price point, both the QCA9882 and QCA9880 are viable alternatives. Regardless of your choice, each WiFi card offers unique features and capabilities that can enhance your OpenWrt experience. 8 Z& x9 H$ L8 F+ ?* k! k$ |7 C
Wallys Modules and Platform DR882 (QCA9882): Chipset: Atheros QCA9882 2x2 5G high-power radio card Frequency range: 4.940GHz to 5.825GHz 2x 5G MMCX connectors Bandwidth: 20MHz/40MHz/80MHz Supports 802.11ac/an standards RoHS compliant 7 i/ Y# Z. B% G3 R: u9 J
DR900VX Chipset: Qualcomm-Atheros QCA9880 Output power: 2.4GHz max 26dBm, 5GHz max 25dBm IEEE 802.11a/b/g/n/ac compliant and backward compatible 3x3 MIMO technology, up to 1.3Gbps Mini PCI Express edge connector RoHS compliant Supports various technologies and IEEE standards (e.g., spatial multiplexing, LDPC codes, MRC, STBC, DFS) FCC, CE, and IC certification 5 j* |; N) e3 T
DR600VX Chipset: Qualcomm-Atheros QCA9880 Output power: 2.4GHz max 24dBm, 5GHz max 23dBm IEEE 802.11a/b/g/n compliant and backward compatible 2x2 MIMO technology, up to 867Mbps Mini PCI Express edge connector Frequency support: 4920MHz~4980MHz RoHS compliant Supports various technologies and IEEE standards (e.g., spatial multiplexing, LDPC codes, MRC, STBC, DFS) FCC, CE certification 5 v: b0 P0 p( y! s# T1 r
DR7915 Chipset: MT7915+MT7975 Host Interface: Mini PCI Express 2.1 Antenna Connector: 2 x UF.L Frequency Range: 2.4GHz: 2.412GHz to 2.472GHz, 5GHz: 5.180GHz to 5.825GHz Operating Voltage: 3.3V DC Power Consumption: 4-8w Modulation Techniques: OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM Environmental Temperature: Operating: -40°C to 70°C, Storage: -40°C to 90°C Environmental Humidity, non-condensing: Operating: 5% to 95%, Storage: Max. 90% ROHS Compliance: YES Dimensions (W×H×D): 51mm × 30mm × 5.8mm
) P7 H) N4 L, Q9 w0 W: d9 MClick below the link for more information of DR7915 ​​https://www.wallystech.com/Network_Card/DR7915-wifi6-MT7915-MT7975-2T2R-support-OpenWRT-802.11AX-supporting-MiniPCIe-Module.html​​ ) M3 F; X! w, \6 _1 @. g
Platform R4019 Featuring with industrial-grade ​​IPQ4019​​/IPQ4029 chipset Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module Support 4.940GHz to 5.825GHz Frequency Range Support 2.400GHz to 2.482GHz Support 2 x 5G MMCX Connectors and 2x2.4G MMCX Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth Support 11ABGN/AC Support fixed data rate RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals Our Firmware supports all the modules of Quectel Support ​​Openwifi​​ Support QSDK Support ​​Openwrt​​
Q8 P W l) r& c$ I6 z. jFeel free to share your thoughts on QCA9882, QCA9880, and MT7915 WiFi cards for OpenWrt in the comments section below.
3 }! c: r2 K4 u6 wWallys is committed to continuous innovation, pushing the boundaries of WiFi technology. Alongside hardware products, Wallys offers ODM/OEM services, including customization to tailor WiFi 6 products and embedded boards to your specific needs, along with engineering support, testing, and certification.
& b% @6 g1 z }3 p& K1 PFor inquiries or to discuss your requirements, contact our dedicated sales team at sales1@wallystech.com.
9 Y2 `0 j' {/ F' oWallys - Empowering Connectivity, Driving Innovation. * _/ O; W; r# Y3 b& w8 [+ p
