IPQ5018 Router and QCN9074 Card: Unleashing Ultra-Fast and Stable WiFi 6E Network Expe**ence the Power of WiFi 6E with IPQ5018 Router and QCN9074 Card Duo Get ready to expe**ence unparalleled speed and stability with the IPQ5018 Router and QCN9074 Card duo. Designed for high-performance wireless ***working, the IPQ5018 boasts integrated 802.11ax Wi-Fi/Bluetooth 5.1 subsystems, delive**ng cost-effective and efficient connectivity. IPQ5018 The IPQ5018 is a highly integrated System-on-Chip (SoC) designed and manufact**ed for high-performance and efficient wireless ***work applications, including home routers, mesh nodes, and gateways. It feat**es integrated 802.11ax Wi-Fi/Bluetooth 5.1 subsystems, providing high efficiency and cost-effectiveness. Key Feat**es: - Wi-Fi subsystem supports IEEE802.11ax, incorporating a wireless radio operating in the 2.4 GHz band with 2 antennas (2x2/40). - Network subsystem: - Low-power PCIe inte***ce with L1 sub-states. - Two Ether*** ports: - One integrated GbE PHY. - One SerDes supporting 3.125/1.25 Gbps Ether*** ports for external 2.5/1 GbE PHY. This SerDes operates in S**II+ or S**II mode to connect to 2.5 GbE PHY or single-port GbE PHY. In today's fast-paced digital world, a reliable and lightning-fast inter*** connection is essential for seamless connectivity. With the advent of WiFi 6E technology, users can now enjoy unprecedented speed, stability, and coverage. The ***bination of the IPQ5018 Router and QCN9074 Card delivers an unparalleled WiFi 6E expe**ence, setting new standards for home and business ***works. The IPQ5018 Router is a powerhouse in the world of ***working, equipped with advanced feat**es and cutting-edge technology to provide ultra-fast and stable connectivity. Its robust hardware ens**es maximum performance, while its intelligent software optimizes ***work traffic for an uninterrupted online expe**ence. Paired with the QCN9074 Card, this duo takes WiFi 6E to new heights. The QCN9074 Card is designed to maximize the capabilities of WiFi 6E, offe**ng higher speeds, lower latency, and increased capacity ***pared to previous generations. With its advanced beamforming and MU-MIMO technology, the QCN9074 Card ens**es optimal signal strength and coverage throughout yo** home or office. Together, the IPQ5018 Router and QCN9074 Card create a WiFi 6E ***work that is not only blazing fast but also incredibly stable. Whether you're streaming 4K videos, gaming online, or video conferencing with colleagues, you can count on a seamless and lag-free expe**ence. But the benefits don't stop there. The IPQ5018 Router and QCN9074 Card also p**o**tize sec**ity, with robust encryption protocols and built-in firewalls to protect yo** ***work from cyber threats. Additionally, advanced parental controls and ***work management tools allow you to customize and monitor yo** ***work with ease. In conclusion, the IPQ5018 Router and QCN9074 Card ***bination is the ultimate solution for those seeking a high-performance WiFi 6E ***work. Expe**ence the fut**e of connectivity today with unparalleled speed, stability, and coverage. DR5018 DR5018 based on IPQ5018 chipset is an enterp**se wireless module integrated with BT5.1 Radio module and 2x2 2.4G high power Radio module designed specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data tran**ission for office and challenging RF environment in facto**es, warehouses establishment. CPU: Qual***m-Atheros IPQ5018 CPU Frequency: Dual-core ARM 64-bit A53 @1.0 GHz processor System Memory: 512MB DDR3L 16-bit inte***ce with 32-bit memory bus design (Optional support for 1G) Ether*** Port: 4 x 1Gbps Ether*** Ports or 1 x 1Gbps Ether*** Port & PoE NGFF Slot: M.2 Card Slot for 5G (QUECTEL RM 500Q-GL); M.2 Card Slot for QCN9074 WIFI 6E Card PoE: Support DC Jack: 12V power supply LED Header: LED for power, WiFi strength Se**al Port: Support Wireless: On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain; 2x IPEX Connectors Bluetooth: BT5.1 (optional) Nor Flash: 8MB Nand Flash: 128 MB DDR: 512MB Dimension: 170mm x 120mm x 15mm DR9074 Chipset: Qual***m Atheros QCN9074 WLAN Host Inte***ce: PCI Express 3.0 Inte***ce System Memory: 2Mbit se**al I²C bus EEPROM Standard Operating Voltage: 5V Operating Systems: QSDK Host Inte***ce: M.2 E Key Antenna Cable / Port: 4 x MMCX Connectors, 4T4R Frequency Range: 5.925GHz-7.125GHz Data Rates: 6GHz, max 23dBm per chain, up to 4804Mbps Channel Spectrum Widths: Support 20/40/80/160MHz at 6GHz Modulation Techniques: OFDMA: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM Temperat**e Range: Operating: -20°C to 70°C, Storage: -40°C to 90°C Humidity: Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing) C***ification: TBD Power Consumption: TBD Reference Design: PN02.7 Dimensions (WxHxD): 57mm x 63mm x 6mm For inqui**es or to discuss yo** specific requirements, please contact o** dedicated sales team at [**l=mailto:sales1@wallystech.***]sales1@wallystech.***[/**l]. Wallys - Empowe**ng Connectivity, D**ving Innovation. ! i, ]/ m- }8 L3 ~: }: \+ A
