查看: 756|回复: 0
D***19|IPQ4019-Based Indust**al Board: Multifunctional with 2 MiniPCIe Suppor...
发表于 2024-4-15 14:25:08 | 显示全部楼层 |阅读模式
D***19|IPQ4019-Based Indust**al Board: Multifunctional with 2 MiniPCIe Support, OpenWRT LTE, WIFI 5G, MT7915, and QCN9074 Platform
Empowe**ng Customization and Connectivity: The IPQ4019-Based Indust**al Board
In the realm of indust**al connectivity, adaptability reigns supreme. Introducing the IPQ4019-based indust**al board, a versatile solution engineered to offer unparalleled customization and connectivity options. Let's explore its key feat**es:
Tailored Dual LTE Support
- This board supports customizable config**ations for dual LTE support, allowing for routerboard/baseboard+SOM setups tailored to specific requirements. Whether it's optimizing bandwidth or ens**ing redundancy, users can fine-tune their connectivity solutions with ease.
Efficient Network Se**entation via VLANs
- Recognizing the importance of ***work se**entation, this board seamlessly integrates VLAN support. Users can create distinct virtual ***works within a single physical infrastruct**e, enhancing sec**ity and efficiency.
Customized L**I Inte***ce
- Elevate brand identity and user expe**ence with a customized L**I inte***ce feat**ing the customer's logo. This personalized touch adds a professional flair while maintaining familia**ty for end-users.
Extended Range Firmware Customization
- Break through geographical bar**ers with custom firmware designed for long-distance transmission, reaching up to 20km. Whether it's remote installations or expansive deployments, rest *****ed that firmware updates will reach even the most remote endpoints.
Seamless Integration with Leading Controllers
- Integrate effortlessly into existing ***work architect**es with support for Wallys AP Controller and TIP Cloud Controller. Benefit from centralized management, config**ation, and monito**ng capabilities, enhancing operational efficiency and scalability.
Conclusion: Unmatched Flexibility for Indust**al Connectivity
In conclusion, the IPQ4019-based indust**al board stands as a beacon of innovation and adaptability in indust**al connectivity. With its support for customizable LTE config**ations, VLANs, branded inte***ces, long-distance firmware transmission, and integration with leading management controllers, this board offers unparalleled flexibility and connectivity options. Whether optimizing performance, enhancing sec**ity, or streamlining operations, this versatile solution is poised to revolutionize indust**al connectivity challenges.
D***19
Feat**ing with indust**al-grade [**l=https://***.wallystech.com/Indust**al_Wireless_AP/DR-AP40X9-A-Qualcomm-IPQ-4019-IPQ-4029-5G-4G-LTE-aluminum-body-dual-band-wifi-router-2.4GHZ-5GHz-QSDK-firmware.html]IPQ4019[/**l]/IPQ4029 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
Support fixed data rate
RoHS compliance ens**e a high level protection of human health and the environment from **sks that can be posed by chemicals
O** Firmware supports all the modules of Quectel
Support [**l=https://telecominfraproject.com/openwifi/]Openwifi[/**l]
Support QSDK
Support [**l=https://downloads.openwrt.org/snapshots/targets/ipq40xx/gene**c/]Openwrt[/**l]
[**l=https://***.wallystech.com/Routerboard/D***X9-Qualcomm-IPQ4019-IPQ4029-DUAL-BAND-802.11AC-W**E2-MU-MIMO-ONBOARD-WIFI-RADIO-EMBEDDED-BOARD-supporting-LTE.html]https://***.wallystech.com/Routerboard/D***X9-Qualcomm-IPQ4019-IPQ4029-DUAL-BAND-802.11AC-W**E2-MU-MIMO-ONBOARD-WIFI-RADIO-EMBEDDED-BOARD-supporting-LTE.html[/**l]
Openwrt Supported and 6E support
With QCN9074 QCN9024 DR9074-6E card
With MT7915 DR7915
About Wallys
Wallys has been a prominent player in the WiFi industry for over 16 years, starting with the QCA chips like AR5414 and AR7161. O** key strength lies in WiFi stability, allowing us to optimize d**vers to counter interference and ens**e long-distance connectivity. We offer customization options, allowing customers to develop their own feat**es by adjusting settings in the register. Additionally, we have exp***ise in developing special protocols such as **MA on WiFi and fast roaming. O** hardware design capabilities enable us to customize solutions based on customer requirements. If you're seeking an OEM/ODM/Software Customization Service provider, feel free to contact us at sales1@wallystech.com.
3 O; r/ B  G# s
