查看: 609|回复: 0
三伍微电子 IoT FEM:GSR2501 WIFI标准 BT 功率20 dBm
发表于 2024-5-11 10:32:43 | 显示全部楼层 |阅读模式
Product Description
The GSR2501 is a high performance, fully integrated RF
front end module (FEM) designed for Bluetooth
(including EDR), Zigbee applications. The device
provides all the functionality of a fully matched power
amplifier (PA), low-noise amplifier (LNA), and two
single-pole, triple-throw (SP3T) switches.
The GSR2501 provides a complete 2.4 GHz WLAN RF
solution from the output of the transceiver to the antenna,
and from the antenna to the input of the transceiver. The
LNA increases the receive sensitivity of embedded
solutions to improve range. The low ins***ion loss and
low current bypass mode decrease the power consumption
when working in a good signal environment. The
GSR2501 also includes digital enable control pins for
power ramp on/off control.
The RF blocks operate over a wide supply voltage range
from 3.0 V to 5.2 V that allows the GSR2501 to be used
in lithium battery powered applications.
The device is provided in a compact, 16-pin 2.3 x 2.3 mm
Quad Flat No-Lead (QFN) package. Pin map is shown in
Figure 1. A functional block diagram is shown in Figure
2.
Key Features
l Saturated output power: 22.5 dBm@3.3 V
l EDR power up to 14 dBm
l Integrated LNA (1.5 dB noise figure)
l Low Ins***ion Loss Bypass Mode
l Single ended transmit/receive inte***ce
l Input and output matched to 50 ohm
l Wide supply range ( 3.0 V to 5.2 V)
l No external bias resistor is required
l High Impedance Control Pin
Applications
l Range extender
l Wireless sound and audio systems
l Custom 2.4 GHz radio systems
l Wireless sensor ***works
l Zigbee smart power
l Zigbee extended range devices
