查看: 369|回复: 1
Wallys DR5018: Dependable WiFi 6 Routerboard for Long-Distance PTP Transmissi...
发表于 2024-6-7 13:33:19 | 显示全部楼层 |阅读模式
Wallys DR5018: Dependable WiFi 6 Routerboard for Long-Distance PTP Transmission with WPA3 SecurityIn today’s industrial environments, reliable long-distance wireless communication is crucial. Whether it’s for factory automation, smart warehousing, or remote monitoring and control, stable and efficient Point-to-Point (PTP) wireless transmission is essential. Wallys' DR5018 WiFi 6 Routerboard, with WPA3 encryption and exceptional PTP transmission performance, is an ideal solution for industrial long-distance communication. Powered by the robust IPQ5018 processor, the DR5018 ensures strong performance and reliability.9 p# E: r" |  s; m7 c
DR5018's PTP Transmission PerformanceThe Wallys DR5018 excels in PTP long-distance transmission on both the 5GHz and 6GHz bands. Here are the performance results from various distance tests:
- b' T" Y9 T$ f1 b# A3.3KM PTP **** (DR5018M)
  • 5GHz: 949Mbps
  • 6GHz: 821Mbps9 }8 b* g) i1 k
1.5KM PTP **** (DR5018M)
  • 5GHz: 1.5Gbps
  • 6GHz: 1Gbps
    8 i; J3 v  j# m' h, N6 F/ P3 Q
These impressive results demonstrate that the DR5018 can maintain high bandwidth and stable connections over long distances, ****** it ideal for a wide range of industrial applications.$ Z# m0 f) K3 x3 B; k
IPQ5018 ProcessorThe DR5018 features Qualcomm’s IPQ5018 processor, designed for high performance and efficiency, offering several advantages:" g! b$ n: i3 H: S1 m
1. High Processing PowerThe IPQ5018 processor boasts a quad-core ARM Cortex-A7 architecture with a clock speed of up to 1.0GHz, efficiently handling numerous concurrent connections and data transmissions to ensure ***work stability and responsiveness.
1 J, f# K7 K/ I: [' ~6 O2. Advanced Network AccelerationIntegrated with Qualcomm’s ***work acceleration technology, the IPQ5018 significantly enhances ***work throughput and data processing efficiency, ensuring exceptional performance even under heavy load.& M- N5 F8 J% L+ |. @3 I; t
3. WiFi 6 Standard SupportSupporting the WiFi 6 (802.11ax) standard, the IPQ5018 incorporates advanced technologies such as OFDMA, MU-MIMO, and 1024-QAM modulation, delivering higher speeds, lower latency, and stronger signal coverage.3 A5 A  Q, H6 [- ~
4. Energy EfficiencyThe IPQ5018 offers outstanding energy efficiency, delivering powerful performance while maintaining low power consumption, ****** it ideal for energy-sensitive industrial environments.
( ?) u8 q7 z& }8 t9 PBenefits of WiFi 6WiFi 6 (802.11ax) brings several advancements that make the DR5018 perform exceptionally well in industrial settings:
/ `9 a* F4 U3 l9 a  D1 g1. Increased Speed and BandwidthWiFi 6 provides higher data tran**er rates and greater bandwidth, supporting high-throughput industrial applications such as HD video surveillance and big data transmission.
6 |( C. F3 F5 P1 Y+ P, q/ k- J) J+ k2. Reduced LatencyWiFi 6’s low latency ensures timely responses for industrial automation and real-time control applications, enhancing operational efficiency and accuracy.
/ H/ G( o% O% l8 D$ Y6 m" J/ b3. Enhanced Device Density SupportWiFi 6 utilizes OFDMA (Orthogonal Frequency Division Multiple Access) technology, allowing multiple devices to transmit data simultaneously, significantly improving ***work efficiency and capacity. This is crucial in device-dense industrial environments./ n% Q" c/ Q' c. W) B0 v" ]
4. Superior Signal CoverageWiFi 6 delivers stronger signal coverage, ensuring stable ***work connections throughout large factories or warehouse facilities.3 I0 K9 W% W1 |
Security with WPA3 EncryptionThe DR5018 supports WPA3 encryption, providing top-tier security for industrial ***works. Compared to WPA2, WPA3 offers several enhancements:
4 e* \9 f& c& }6 d1. Robust Encryption AlgorithmsWPA3 uses more robust encryption algorithms, delivering higher security and ensuring data safety during transmission.; ]  n9 c8 [9 L. u, l5 E0 @
2. Protection Against Man-in-the-Middle AttacksWPA3 enhances authentication mechanisms to effectively prevent Man-in-the-Middle (MitM) attacks, ensuring data integrity and confidentiality in industrial environments.
( A; ^  F: U# @4 ~% b" b) M3. Secure Public Network ConnectionsWPA3 includes Individualized Data Encryption, ensuring that each device’s communication is independently encrypted, even on public ***works, enhancing security.
# a4 r. @; f+ r: V; m4. Simplified Device ConfigurationWPA3 simplifies device configuration and connection processes, allowing industrial devices to securely and quickly join the ***work, reducing configuration errors.
# h# ]* Q, t& a6 O: p: SIndustrial Applications of DR5018With its powerful PTP transmission capabilities and advanced encryption technologies, the DR5018 Routerboard is suitable for various industrial applications:
! R) p, b( N- Q, t$ F% X/ V1. Factory AutomationIn automated production lines, the DR5018 provides efficient and stable wireless connections, supporting real-time data transmission and device control, boosting production efficiency and accuracy.
6 X4 H% G/ ^9 e9 ?: O  Q! _  ^1 r' x2. Smart WarehousingIn smart warehousing systems, the DR5018 supports large-scale device concurrent connections and data transmissions, ensuring efficient and precise warehouse operations.
/ ^* M! H7 e# X) g/ n- B1 t2 h3. Industrial SurveillanceIn industrial surveillance systems, the DR5018 offers low-latency and highly reliable wireless connections, supporting HD video transmission and real-time monitoring, ensuring production safety.
! Y" N( J+ ^" j7 U0 y" ?- h4. Remote Operation and ControlFor applications requiring remote operation and control, the DR5018 provides stable long-distance wireless connections, ensuring operational accuracy and real-time response.
! X0 c  J$ f  W4 {ConclusionWallys' DR5018 WiFi 6 Routerboard, with WPA3 encryption, the powerful IPQ5018 processor, and excellent PTP transmission performance, provides comprehensive protection and reliability for industrial ***works. Its outstanding performance and security features meet the needs of various industrial applications, ensuring safe data transmission and stable ***work connections.
3 `( S8 m- t+ \% Y2 D2 YChoosing Wallys DR5018 means selecting a wireless ***work solution that delivers optimal performance and top-tier security for industrial environments. Whether it’s data transmission, device connectivity, real-time monitoring, or control, the DR5018 meets your needs and becomes a reliable partner in building your industrial ***work.
* Q% B5 Z: z5 W. g; P! B5 cFor more information, please contact us at [url=]sales1@wallystech.com[/url].
7 U/ l% s$ p2 @) U4 Y( L
% {$ @. }/ g; x# P
发表于 2024-6-11 09:19:30 | 显示全部楼层
1111111111111
