查看: 713|回复: 0
IPQ8072 vs IPQ8064: What is the Difference?
发表于 2024-6-18 17:17:01 | 显示全部楼层 |阅读模式
IPQ8072 vs IPQ8064: What is the Difference?When comparing the IPQ8072 and IPQ8064 chipsets from Qualcomm, it's clear that they represent different generations of technology with various advancements in performance and features. Here are the key differences:
Processor and Performance
  • IPQ8064:
    • CPU: Dual-core SMP Krait CPU
    • Clock Speed: 1.4 GHz
    • Architecture: ARM-v7-compliant
    • Cache: 1 MB L2 cache, 16 KiB L1 I-Cache and 16 KiB L1 D-Cache
  • IPQ8072:
    • CPU: Quad-core ARM Cortex-A53
    • Clock Speed: Up to 2.2 GHz
    • Architecture: ARM-v8-compliant
    • Cache: More cores and higher clock speed for better performance
Wi-Fi Standards and Bands
  • IPQ8064:
    • Wi-Fi Standard: 802.11ac (Wi-Fi 5)
    • Bands: Dual-band (2.4 GHz and 5 GHz)
    • Speed: Supports up to AC2600 class speeds
  • IPQ8072:
    • Wi-Fi Standard: 802.11ax (Wi-Fi 6)
    • Bands: Tri-band (2.4 GHz, 5 GHz, and 6 GHz)
    • Speed: Supports up to AX6000 class speeds
Networking Capabilities
  • IPQ8064:
    • Networking Subsystem (NSS): Aggregate throughput capacity of 5 Gbps
    • NSS Engines: Two programmable, multithreaded ***work accelerator engines, each supporting 12 threads
    • Functions: L2/L3 routing/bridging, Samba acceleration, LRO/TSO offload, connectivity acceleration, traffic management
  • IPQ8072:
    • Advanced Networking: Enhanced support for OFDMA, MU-MIMO, and other Wi-Fi 6 features
    • Security: Enhanced features like WPA3 for better security
Inte***ces and Connectivity
  • IPQ8064:
    • **ACs:
      • 1×QS**II
      • 3×S**II and 1×R**II
      • 2×S**II and 2×R**II
    • PCIe: 3×PCIe 2.0 (root complex)
    • USB: 2×USB 3.0 (host and device mode)
    • SATA: 1×SATA 3
    • Memory: 32-bit DDR3/1066
    • NAND/SDIO: 8-bit NAND/SDIO, ECC 8b/512, 16b/1024, 4-bit SDIO
    • Additional Inte***ces: HSIC, 2×Transport Stream Inte***ce (TSIF), 6×General-purpose serial inte***ces (GSBI), JTAG
  • IPQ8072:
    • Ether*** Ports: Supports up to 10 Gigabit Ether*** ports
    • Memory: Supports DDR4 memory
    • Additional High-Speed and General-Purpose Inte***ces: Enhanced connectivity options for modern ***working needs
Advanced Features
  • IPQ8064: Suitable for high-performance consumer routers and enterprise access points with early 802.11ac adoption
  • IPQ8072: Designed for the latest generation of high-performance routers and access points, supporting modern Wi-Fi 6 standards, higher data throughput, and more connected devices
Summary of Key Differences
  • Processor: IPQ8072 has a quad-core ARM Cortex-A53 CPU with higher clock speeds, compared to the dual-core Krait CPU in IPQ8064.
  • Wi-Fi Standard: IPQ8072 supports the latest 802.11ax (Wi-Fi 6) standard, while IPQ8064 supports 802.11ac (Wi-Fi 5).
  • Bands: IPQ8072 supports tri-band, including the new 6 GHz band, whereas IPQ8064 supports dual-band.
  • Networking Capabilities: IPQ8072 features advanced ***working capabilities like OFDMA, MU-MIMO, and WPA3 security.
  • Inte***ces and Memory: IPQ8072 supports more Ether*** ports and DDR4 memory, compared to IPQ8064's DDR3 support.
  • Advanced Features: IPQ8072 is built for modern, high-performance ***working with support for Wi-Fi 6 and enhanced connectivity, ****** it suitable for dense environments and future-proof applications.
ConclusionThe IPQ8072 offers significant improvements over the IPQ8064 in terms of processing power, Wi-Fi standards, band support, advanced ***working features, and overall connectivity options. This makes the IPQ8072 a superior choice for building next-generation ***working devices.
Wallys Communications (Suzhou) Co., Ltd., known as a specialist in researching, developing, and producing wireless communication products, offers star products such as router boards, ***work cards, industrial wireless APs, and antennas.
With professional R&D teams possessing over 15 years of experience, we not only provide OEM/ODM/JDM services but also offer customization services to meet your needs—from idea design to manufacturing and market launch.
Email us at [url=]sales1@wallystech.com[/url]
Visit our website: www.wallystech.com
