查看: 723|回复: 0
无电感锂电池升压IC(5V 230MA)PS3120A
发表于 2024-8-21 17:53:15 | 显示全部楼层 |阅读模式
库存        9870000! V% H2 \, X$ w1 ?/ n: \
品牌        PULAN PS3120A" V1 W% R) ]8 G& ]! q
输入电压        2.7V to 4.5V
% }! D+ s. }3 K3 _& F' S5 G$ Z输出电压        4.94V±3%
% M! _6 c. n- x+ G2 e) x2 D6 M输出电流        110mA (VIN≥3V) Up to 230mA (VIN≥3.6V)# v& o  Y2 A. r( J' G! M$ R+ G( X
The PS3120A is a low noise switched capacitor voltage doubler. It produces a regulated output voltage from a 2.7V to 4.5V input. Low external parts count (one flying capacitor and two small bypass capacitors at VIN and VOUT) make the PS3120A ideally suited for small, battery-powered applications.  5 I  e. g/ y7 J5 d7 b3 ~# F& I( Q! [% `
( a; h" f3 x5 y8 H6 h
       The PS3120A have thermal shutdown capability and can survive a continuous short circuit from VOUT to GND. A low current
4 T0 [$ M& O) {+ C" z. v5 zshutdown feature disconnects the load from VIN and reduces quiescent current to <1μA. 9 }& u2 M3 v' j) `4 I1 H
        The PS3120A is available in the industry standard SOT-23-6L power packages.: I. P$ ]& [) c+ N
PS3120A是不需要电感的锂电池升压IC,输出电压4.94V,输出电流最大可以做到230MA。比较适合用在小功率的电子产品中。
& Y% g" n3 K! i6 S9 W& ?' j2 P, A
1 V/ h6 |6 i0 A6 B* vFixed 4.94V±3% Output
/ h, S: X* x- @&#61656;  VIN Range: 2.7V to 4.5V
$ \3 L( |; n# K&#61656;  Output Current: Up to 110mA (VIN≥3V)
: Z7 Z, S- x# {3 }! RUp to 230mA (VIN≥3.6V)
3 [' E! C3 m6 n8 a+ p4 a&#61656;  Low Noise Constant Frequency (360kHz) ' i& S2 ?8 w; E: D$ G9 [+ U6 B) c
Operation 6 ^5 V, r% v  Q7 c+ m( G. f$ K$ P
&#61656;Shutdown Current <1μA
% F7 t9 Q* r9 c/ T4 b8 |. w' \&#61656;No Inductors
) M% ?7 w1 H- w3 L+ i; c5 |/ h8 A9 X&#61656;  Available in Low Profile 6-Lead SOT23 + }8 q3 ?1 r7 a! b. x
Package
