查看: 226|回复: 0
Advanced Design System ADS 2020 Update 2.0 独立安装版本
发表于 2020-5-22 21:09:00 | 显示全部楼层 |阅读模式
关于 Advanced Design System ADS 2020 的简介可访问老wu博客里之前发布的文章:https://www.mr-wu.cn/advanced-design-system-2020-free-download-and-crack/
老wu这里分享的 Advanced Design System ADS 2020 Update 2.0 虽然带个Update字样,但这不是补丁,是完全独立安装的版本,可以理解为ADS 2020.2这样的小版本号的更新版本,这里分享的是Windows下的64位版本,至于Linux下的版本,老wu这里暂时木有收藏,抱歉   (°°)~
ADS 2020 Update 2.0 主要是修复了一些已知的bug,也有可能在不小心的情况下引入了一些未知的bug,然后增加了一些好用的新特性,比如老wu感兴趣的高速互联以及EM-SI/EM-PI方面的增强:
SerDes
Introduced the E-O-E (Electrical-Optical-Electrical) integrated work flow with VPIphotonics for Datacom and Telecom markets. The VOL (VPI Optical Link) component must have a valid Simulation: Link_to_VPI license for the co-simulation. This enables the users to consider the optical channel effect in the design of the end-to-end link analysis, such as:
  • Nonlinear wavelength-dependent transfer function of Electro-Absorption Modulators (EAM)
  • Nonlinearity
  • Relative Intensity Noise (RIN)
  • Fiber attenuation
  • Dispersion
    DDR/Memory
  • New DDR5 and LPDDR5 solutions with IBIS-AMI modeling for equalizations
  • Jitter tracking for optimal DFE clocking with internal phase interpolator training
  • Automated DDR5 compliance test on simulated waveforms
  • Streamlined memory design workflow such as integrated package setup in to Controller and Memory to reduce wiring
  • Controller, Memory, and Termination GUI improvement and group editing for DDR_Termination component for better usability
    EM-SI/EM-PI
  • Context-Aware Signal Name Matching algorithms in SIPro
  • Added delay plot in the results window.
  • Added dc frequency (0 Hz) support for Logarithmic frequency plan in Via designer.
  • Added option to set number of samples for siodump.
  • Component Model Library Tools now work with .brd and odb++ imported PCB data.
  • PIPro DC Results Power Tree speed improvements and the ability to handle multiple power rails in one design analysis.
    安装方法可以参考老wu之前发布的ADS 2020初始版本的安装方法,这个链接:https://www.mr-wu.cn/advanced-design-system-2020-free-download-and-crack/
    ADS 2020 Update 2.0 的License特性与之前的不一样了,所以需要新的河蟹文件和方法。
    1。假设你已经参考之前ads 2020初始版本的安装步骤安装好了 ads 2020 update 2.0版本,在弹出【License Setup Wizard】需要你选择license的时候,直接按【退出】
    2。拷贝老wu分享的crack文件夹里头的【ADS2020_update2】和【EEsof_License_Tools】这两个文件夹,复制到ads 2020 update 2.0的安装目录下覆盖现有文件。
    举个栗子:比如你将ads 2020 update 2.0 安装到 C盘下,那就把crack文件夹下的【ADS2020_update2】和【EEsof_License_Tools】这两个文件夹复制粘贴到【C:\Program Files\Keysight\ADS2020_update2】这个目录下,具体的路径以你的安装目录为准,覆盖掉所有的重复文件和文件夹
    3。覆盖粘贴完成之后(对!一定要先进行第2步之后再执行第3步),进入您ads 2020 update 2 的安装目录,也就是你刚才覆盖的目录,进入子目录【EEsof_License_Tools\bin\win32_64\】,里头有server_install.bat以及server_remove.bat这两个文件。
    先以管理员权限运行server_remove.bat(注意,以管理员权限运行!!!可以通过鼠标在文件上右键点击,在弹出菜单中选择【以管理员身份运行】),运行server_remove.bat先删除现有的license 服务,然后再以管理员权限运行server_install.bat,注册新的license服务。
    最后,双击crack文件夹内的【Keysight_Licensing】注册表文件导入注册表信息,搞定 (●’?’●)
    ADS 2020 update 2.0 软件下载
    关注吴川斌的博客公众号
    在公众号里给老吴发消息:
    下载|ADS2020
    或者
    下载|600030
    建议复制粘贴过去不会码错字哟,O(∩_∩)O~
    老wu便会将 ADS 2020 下载链接发给您啦,O(∩_∩)O~
