查看: 411|回复: 0
DR9074-6G | QCN9074 QCN9024 Wi-Fi 6E 6GHz MU-MIMO Qualcomm 11AX WPA3 4x4 2x2 ...
发表于 2024-9-9 14:46:34 | 显示全部楼层 |阅读模式
DR9074-6G | QCN9074 QCN9024 Wi-Fi 6E 6GHz MU-MIMO Qualcomm 11AX WPA3 4x4 2x2 Module - WallysProduct Features:
) K6 ]( X# R/ O
  • Chipset: Qualcomm Atheros QCN9074
  • Frequency: 6GHz, max output 23dBm per chain, supports up to 4804Mbps
  • Band: Single Band 6GHz 4x4 Wi-Fi 6E (802.11ax)
  • Spatial Streams: 4 spatial streams (4SS)
  • Inte***ce: M.2 E Key Inte***ce
  • PCI Express: PCIe 3.0 Inte***ce- Z! ]" Z& Y, U. u" e) [
Recommended Mainboards:
" {6 T7 E4 ^" u; s
  • Wi-Fi 6 (802.11ax):
    4 f3 o0 h$ a6 W  C% w4 d, ~* N. T  ?3 N; ^- r
    • DR5018: Best value option
    • DR6018: Combines good value with moderate performance
    • DR8072: High-performance option
      . n3 ?! N  T+ Y% p
  • Wi-Fi 7 (802.11be):
    9 @9 T: t/ M$ o# T. L6 v" N: i: D8 B# d' S! {' n& w- h$ h
    • DR9574: High-performance option
    • DR5332: Best value option
      0 _5 l% D) M( j! c
Other QCN9074/QCN9024 Network Cards:$ X7 l8 l' i: E! d7 N; T
  • 2.4GHz: DR9074-2.4G
  • 5GHz: DR9074-5G
  • 2.4GHz & 5GHz: DR9074E-DB
  • 5GHz & 6GHz: DR9074E
  • 2.4GHz, 5GHz & 6GHz: DR9074-Triband: _/ n4 O. E7 K6 t6 O5 J- r
4 d5 F7 D6 c* @5 S4 QNeed Help Deciding?
; q7 r$ b' F( b8 f0 [) sFor corporate or customized projects, contact our professional sales team for timely and effective pre-sales consultation. Let us help you find the best solution for your project.
/ [' W# S! u( T+ E7 f4 G4 OEmail: [url=]sales1@wallystech.com[/url]( q/ m/ h9 e, L6 \
For more information, visit Wallys Communications (Suzhou) Co., Ltd..& t7 M' g! ?2 P# P) X
9 t/ B) m2 e. T. G# c: ~2 _
