查看: 235|回复: 0
MATLAB |不给糖果就捣蛋
发表于 2023-11-1 13:05:00 | 显示全部楼层 |阅读模式
点击上方蓝字和“好玩的MATLAB”一起快乐玩耍吧!
好玩的matlab
带你解锁不一样的matlab新玩法
万圣节??到了,今天介绍一下怎么用 MATLAB 整活,喜欢此推文的小伙伴们记得点赞+关注+分享!【尊重作者劳动成果,转载请注明推文链接和公众号名】
效果图
代码绘制南瓜
  • clc;clear;close all;[X,Y,Z]=sphere(200);R=1+(-(1-mod(0:.1:20,2)).^2)/15;surf(R.*X,R.*Y,(.8+(0-(1:-.01:-1)'.^4)*.2).*Z.*R,'FaceC',[ 1 0.4588 0.0941],'EdgeC','n')axis('equal','off')material([ .6, .9, .3, 2, .5 ])lighting gcamlight
    绘制无脸男小鬼
  • clc;clear;close allfig=figure('Position',[476 224 672 642]);ax=gca;ax.Color='none';ax.YLim=[0,15];ax.XLim=[-3,14];ax.Box='off';ax.XColor='none';ax.YColor='none';axis equal;hold onpause(0.1)[X, Y] = meshgrid(linspace(1, 0, 200));image([-3, 14], [0, 15], Y*255);colormap(gray)pause(0.1)ellipse = EllipsePlotter('a', 4, 'b', 6, 'x', 5.4, 'y', 6.2, ...    'plotType', 'fill', 'fillColor', [.4,.4,.4], 'rotation', 0, ...    'angleRange',[-25,205],'alpha',1,'lineWidth',6,'lineColor',[1,1,1]*0.9);ellipse.plotEllipse();d=[0 -0.3 -0.4 -0.6 -0.4 -0.3 0];for i=1:7    ellipse = EllipsePlotter('a',1.2, 'b', 3.3, 'x', 2.7+(i-1)*0.9, 'y', 5.5+d(i), ...        'plotType', 'fill', 'fillColor',[.4,.4,.4], 'rotation', 0, ...        'angleRange',[-200,20],'alpha',1,'lineWidth',6,'lineColor','none');    ellipse.plotEllipse();end% 脸pause(0.3)FaceColor=[1.0 0.9627 0.9235];ellipse = EllipsePlotter('a',3, 'b', 2.8, 'x',5.4, 'y',9, ...    'plotType', 'fill', 'fillColor',FaceColor, 'rotation', 0, ...    'angleRange',[0,360],'alpha',1,'lineWidth',2,'lineColor','none');ellipse.plotEllipse();% 眉毛、腮红、嘴pause(0.3)ellipse = EllipsePlotter('a',0.3, 'b',1, 'x',3.9, 'y',10.2, ...    'plotType', 'fill', 'fillColor',[1.0 0.65 0.63], 'rotation', 15, ...    'angleRange',[0,360],'alpha',1,'lineWidth',2,'lineColor','none');ellipse.plotEllipse();
    ellipse = EllipsePlotter('a',0.3, 'b',1, 'x',6.8, 'y',10.4, ...    'plotType', 'fill', 'fillColor',[1.0 0.65 0.63], 'rotation', 160, ...    'angleRange',[0,360],'alpha',1,'lineWidth',2,'lineColor','none');ellipse.plotEllipse();ellipse = EllipsePlotter('a',0.3, 'b',1, 'x',7, 'y',7.8, ...    'plotType', 'fill', 'fillColor',[1.0 0.65 0.63], 'rotation', 0, ...    'angleRange',[-200,20],'alpha',1,'lineWidth',2,'lineColor','none');ellipse.plotEllipse();ellipse = EllipsePlotter('a',0.3, 'b',1, 'x',4, 'y',7.6, ...    'plotType', 'fill', 'fillColor',[1.0 0.65 0.63], 'rotation', -10, ...    'angleRange',[-200,20],'alpha',1,'lineWidth',2,'lineColor','none');ellipse.plotEllipse();pause(0.3)ellipse = EllipsePlotter('a',.84, 'b',1.1, 'x',3.9, 'y',8.9, ...    'plotType', 'fill', 'fillColor',FaceColor, 'rotation', 0, ...    'angleRange',[0,360],'alpha',1,'lineWidth',2,'lineColor','none');ellipse.plotEllipse();ellipse = EllipsePlotter('a',.84, 'b',1.2, 'x',7, 'y',9, ...    'plotType', 'fill', 'fillColor',FaceColor, 'rotation', 0, ...    'angleRange',[0,360],'alpha',1,'lineWidth',2,'lineColor','none');ellipse.plotEllipse();%嘴巴pause(0.3)ellipse = EllipsePlotter('a',.3, 'b',.5, 'x',5.3, 'y',7.9, ...    'plotType', 'fill', 'fillColor',[0.9 0 0], 'rotation', 0, ...    'angleRange',[-180,0],'alpha',1,'lineWidth',2,'lineColor','none');ellipse.plotEllipse();
    ellipse = EllipsePlotter('a',.5, 'b',.25, 'x',5.3, 'y',8, ...    'plotType', 'fill', 'fillColor',FaceColor, 'rotation', 0, ...    'angleRange',[-180,0],'alpha',1,'lineWidth',2,'lineColor','none');ellipse.plotEllipse();%眼袋pause(0.2)ellipse = EllipsePlotter('a',0.3, 'b',0.1, 'x',3.9, 'y',8.2, ...    'plotType', 'fill', 'fillColor',[1 1 1]*0.8, 'rotation', 0, ...    'angleRange',[0,360],'alpha',1,'lineWidth',2,'lineColor','none');ellipse.plotEllipse();ellipse = EllipsePlotter('a',0.3, 'b',0.11, 'x',7, 'y',8.2, ...    'plotType', 'fill', 'fillColor',[1 1 1]*0.8, 'rotation', 0, ...    'angleRange',[0,360],'alpha',1,'lineWidth',2,'lineColor','none');ellipse.plotEllipse();% 眼睛pause(0.3)ellipse = EllipsePlotter('a',0.7, 'b',0.6, 'x',3.9, 'y',9.1, ...    'plotType', 'fill', 'fillColor',[0 0 0], 'rotation', 0, ...    'angleRange',[0,360],'alpha',1,'lineWidth',2,'lineColor','none');ellipse.plotEllipse();ellipse = EllipsePlotter('a',0.7, 'b',0.6, 'x',7, 'y',9.1, ...    'plotType', 'fill', 'fillColor',[0 0 0], 'rotation', 0, ...    'angleRange',[0,360],'alpha',1,'lineWidth',2,'lineColor','none');ellipse.plotEllipse();% 心pause(0.3)t=0:0.025:2*pi;x=(16*sin(t).^3)/10+5.5;y=(13*cos(t)-5*cos(2*t)-2*cos(3*t)-cos(4*t))/10+4.8;fill(x,y,'r','edgecolor','r');%风车pause(0.3)plot([0 0.2],[9.5 7],'LineWidth',3,'Color',[0,0,1,0.5]) colors = {'r', 'g', 'b', 'y';'c', 'm', 'g','c'};L = 0.8;center = [0,9.5]; % 定义风车的圆心T=[0 pi/3];for j = 1:4    for i=1:2        theta1 = (j-1) * pi/2+T(i);        theta2 = theta1 + pi/2;        P0 = center;        P1 = center + L * [cos(theta1), sin(theta1)];        P2 = center + L * [cos(theta2), sin(theta2)];        Psharp = (P1 + P2) / 2;        fill([P0(1), P1(1), Psharp(1)], [P0(2), P1(2), Psharp(2)], colors{i,j},'EdgeColor','none','FaceAlpha',0.8);    endend%手pause(0.3)ellipse = EllipsePlotter('a',3, 'b',0.8, 'x',8.5, 'y',6, ...    'plotType', 'fill', 'fillColor',[.4 .4 .4], 'rotation', -30, ...    'angleRange',[100,250],'alpha',1,'lineWidth',2,'lineColor',[1,1,1]*0.6);ellipse.plotEllipse();ellipse = EllipsePlotter('a',3, 'b',0.8, 'x',8.7, 'y',6.1, ...    'plotType', 'fill', 'fillColor',[.4 .4 .4], 'rotation', -30, ...    'angleRange',[100,250],'alpha',1,'lineWidth',2,'lineColor','none');ellipse.plotEllipse();pause(0.3)ellipse = EllipsePlotter('a',3, 'b',0.8, 'x',2.6, 'y',6, ...    'plotType', 'fill', 'fillColor',[.4 .4 .4], 'rotation',20, ...    'angleRange',[100,270],'alpha',1,'lineWidth',2,'lineColor',[1,1,1]*0.6);ellipse.plotEllipse();ellipse = EllipsePlotter('a',3, 'b',0.8, 'x',2.7, 'y',5.95, ...    'plotType', 'fill', 'fillColor',[.4 .4 .4], 'rotation',20, ...    'angleRange',[100,270],'alpha',1,'lineWidth',2,'lineColor','none');ellipse.plotEllipse();pause(0.3)tex=sprintf('不给糖果
      就捣蛋');text(8,13,tex,'FontSize',30,'FontWeight','bold','Color','w');
    其中绘制风车代码:
  • hold onplot([0 0.2],[9.5 7],'LineWidth',3,'Color',[0,0,1,0.5]) colors = {'r', 'g', 'b', 'y';'c', 'm', 'g','c'};L = 0.8;center = [0,9.5]; % 定义风车的圆心T=[0 pi/3];for j = 1:4    for i=1:2        theta1 = (j-1) * pi/2+T(i);        theta2 = theta1 + pi/2;        P0 = center;        P1 = center + L * [cos(theta1), sin(theta1)];        P2 = center + L * [cos(theta2), sin(theta2)];        Psharp = (P1 + P2) / 2;        fill([P0(1), P1(1), Psharp(1)], [P0(2), P1(2), Psharp(2)], colors{i,j},'EdgeColor','none','FaceAlpha',0.8);    endend
    其中爱心代码:
  • t=0:0.025:2*pi;x=(16*sin(t).^3)/10+5.5;y=(13*cos(t)-5*cos(2*t)-2*cos(3*t)-cos(4*t))/10+4.8;fill(x,y,'r','edgecolor','r');
    其中 EllipsePlotter类函数代码如下
  • classdef EllipsePlotter    properties        a = 1;        b = 1;        x = 0;        y = 0;        angleRange = [0 2*pi];        rotation = 0;        lineColor = 'b';        lineWidth = 1;        plotType = 'plot';        fillColor = 'r';        alpha = 1;    end    methods        function obj = EllipsePlotter(varargin)            % Constructor            if nargin > 0                for i = 1:2:nargin                    obj.(varargin{i}) = varargin{i+1};                end            end            startRadian = obj.angleRange(1) * pi / 180;            endRadian = obj.angleRange(2) * pi / 180;            theta = startRadian:pi/100:endRadian;        end        function plotEllipse(obj)            startRadian = obj.angleRange(1) * pi / 180;            endRadian = obj.angleRange(2) * pi / 180;            theta = startRadian:pi/100:endRadian;            X = obj.a * cos(theta);            Y = obj.b * sin(theta);            % 旋转坐标            rotationMatrix = [cosd(obj.rotation), -sind(obj.rotation); sind(obj.rotation), cosd(obj.rotation)];            xyRotated = [X; Y]' * rotationMatrix;            % 将旋转后的椭圆平移到指定的位置            XY(:,1) = xyRotated(:,1) + obj.x;            XY(:,2) = xyRotated(:,2) + obj.y;            % 根据 plotType 来绘制椭圆            if strcmp(obj.plotType, 'plot')                plot(XY(:,1), XY(:,2), '-', 'Color', obj.lineColor, 'LineWidth', obj.lineWidth);                hold on; axis equal            elseif strcmp(obj.plotType, 'fill')                fill(XY(:,1), XY(:,2), obj.fillColor, 'EdgeColor', obj.lineColor, 'FaceAlpha', obj.alpha, 'LineWidth', obj.lineWidth);                hold on; axis equal            else                error('无效的 plotType 参数!');            end        end    endend
    属性 (properties)这些属性定义了椭圆的参数和绘图样式。
    a, b: 椭圆的主轴和次轴的长度。
    x, y: 椭圆的中心位置。
    angleRange: 绘制椭圆的角度范围。
    rotation: 椭圆的旋转角度。
    lineColor: 椭圆边界的颜色。
    lineWidth: 椭圆边界的线宽。
    plotType: 绘图类型,可以是 'plot' 或 'fill'。
    fillColor: 如果 plotType 是 'fill',则此属性定义填充颜色。
    alpha: 填充的透明度。
    方法 (methods)这些方法定义了类的功能。
    构造函数 (EllipsePlotter):
    当创建这个类的对象时,它会被调用。
    它接受一系列的名称-值对参数,允许在创建对象时设置属性。
    它目前只计算了一个角度范围,但并没有使用这个范围做任何其他事情。
  • plotEllipse:
    该方法根据对象的属性值绘制一个椭圆。
    它首先计算了椭圆上的点的坐标。
    然后根据 rotation 属性旋转这些点。
    接着将旋转后的点平移到 x 和 y 属性指定的位置。
    最后,根据 plotType 属性选择绘制方式:'plot' 会绘制椭圆的轮廓,而 'fill' 会填充椭圆。
    [/ol]这个类可以使用户轻松地创建和定制椭圆的绘图,而不必每次都重复相同的计算和绘图代码。例如,用户可以轻松地更改椭圆的大小、位置、颜色和旋转,并立即看到结果。- -THE END- -
    源码下载:gitee下载:https://gitee.com/iDMatlab/ghost
    QQ群下载:
    参考资料:
    【1】【好玩的源码】MATLAB画冰墩墩【2】【好玩的源码】儿童节快乐!送你一只可爱的小猪佩琪
    送书活动
    包邮赠送 「北京大学出版社赞助《AI时代Excel数据分析提升之道》AI时代Excel数据分析提升之道:知识精进+学习答疑+上机实训+综合实战+ChatGPT应用,零基础入门,极速提升数据分析效率!
  • 零基础入门宝典,由浅入深讲解,无须额外的背景知识即可学习掌握。
  • 内容系统全面,可帮助读者快速了解使用Python进行Excel数据分析的基本语法并掌握开发能力。
  • 理论与实践相结合,每个理论都有对应的代码示例,读者参考代码示例完成编写,就可以看到实践效果。
  • 本书配有实训与问答,方便读者阅读后尽快巩固知识点,做到举一反三、学以致用。
  • AI前沿产品ChatGPT+Python进行Excel数据分析,大幅学习和分析的效率
    了解更多
    【抽奖方式及满足条件】:
    1.关注「好玩的MATLAB 」公众号和视频号
    2.给本文点【】+【在看】;
    3.留言区评论点赞最多的前3名。
    4.本活动只针对从未获过奖的同学,之前获过奖的小伙伴,不用参加。
    同时满足上述4个条件的读者朋友,包邮赠送一本。
    【开奖时间】:2023年11月2日中午12点
    【领奖方式】:在开奖时加小编私人微信:idmatlab
    扫一扫加管理员微信
