查看: 70|回复: 0
MATLAB|制作圣诞节专属头像
发表于 2023-12-22 21:49:00 | 显示全部楼层 |阅读模式
点击上方蓝字和“好玩的MATLAB”一起快乐玩耍吧!
5 F: @5 P+ ~+ d. y7 R+ K$ ]( E% p
0 ?. X* e2 u$ ]: g- e好玩的matlab0 K7 p8 Q- v  O8 ^9 R
带你解锁不一样的matlab新玩法# W! x; j. A$ k7 ^* R
( m( ^( B* d  C今天介绍一下怎么利用Matlab制作圣诞节专属头像,喜欢此推文的小伙伴们记得点赞+关注+分享!【尊重作者劳动成果,转载请注明推文链接和公众号名】
6 r* O. ~3 r& k2 W$ @3 p4 e! [9 k0 z' L! T效果图' K7 S$ q7 M4 A$ ?& d, J
" ]$ q7 V" T# K  k
5 w, p" M; }5 ^
0 A2 \$ J9 y. I' J  ^. O
9 M, x  b  A8 G# f2 a$ E) N2 m程序介绍
( t- c- J& \8 e! V5 M0 C2 M4 a主界面
, `, Y. U+ d3 L6 M, u; {
  • function addHatmFig = figure('units', 'pixels', 'position', [400 300 400 600], ...    'Numbertitle', 'off', 'menubar', 'none', 'resize', 'on', ...    'name', '公众号:好玩的Matlab');axes('parent', mFig, 'position', [0 0 1 1], ...    'XLim', [0 400], ...    'YLim', [-200 400], ...    'NextPlot', 'add', ...    'YDir', 'reverse', ...    'XTick', [], ...    'YTick', [],...    'layer', 'bottom', ...    'Visible', 'on');[avatar, ~, ~] = imread('tx1.jpg');[decorImg, ~, alphaImg] = imread('./img/2.png');ImgResult=image([0 400], [0 400], avatar);添加帽子
  • hatPos = [200, 40];[n, m, ~] = size(decorImg);enlarge=0.08;DrawHatHdl = image([hatPos(1) - m* enlarge hatPos(1) + m* enlarge], ...    [hatPos(2) - n* enlarge hatPos(2) + n* enlarge], decorImg, 'AlphaData', alphaImg);DrawHatHdl.HitTest = 'on';鼠标监听代码
  • set(gcf,'WindowButtonDownFcn', @clickBoat);    function clickBoat(~, ~)        clickType = get(gcf, 'SelectionType');        XY = get(gca, 'CurrentPoint');        if strcmp(clickType, 'normal')            Y = XY(1, 2);            X = XY(1, 1);            set(DrawHatHdl, 'XData', [X - m* enlarge X + m* enlarge], 'YData', [Y - n* enlarge Y + n* enlarge]);        elseif strcmp(clickType, 'alt')            Y = XY(1, 2);            X = XY(1, 1);            enlarge=enlarge*1.1;            set(DrawHatHdl,  'XData', [X - m*enlarge X + m*enlarge], 'YData', [Y - n*enlarge Y + n*enlarge]);        end    endend
    , x+ S  G& Y  ?' S7 }; E操作方法:
  • 鼠标右击放大帽子
  • 鼠标左击移动帽子位置全部代码, _! S5 t; Z& S
  • function addHatmFig = figure('units', 'pixels', 'position', [400 300 400 600], ...    'Numbertitle', 'off', 'menubar', 'none', 'resize', 'on', ...    'name', '公众号:好玩的Matlab');axes('parent', mFig, 'position', [0 0 1 1], ...    'XLim', [0 400], ...    'YLim', [-200 400], ...    'NextPlot', 'add', ...    'YDir', 'reverse', ...    'XTick', [], ...    'YTick', [],...    'layer', 'bottom', ...    'Visible', 'on');[avatar, ~, ~] = imread('tx1.jpg');[decorImg, ~, alphaImg] = imread('./img/2.png');ImgResult=image([0 400], [0 400], avatar);hatPos = [200, 40];[n, m, ~] = size(decorImg);enlarge=0.08;DrawHatHdl = image([hatPos(1) - m* enlarge hatPos(1) + m* enlarge], ...    [hatPos(2) - n* enlarge hatPos(2) + n* enlarge], decorImg, 'AlphaData', alphaImg);DrawHatHdl.HitTest = 'on';" t* `6 o/ U2 p) C/ ?- Q- t
    set(gcf,'WindowButtonDownFcn', @clickBoat);    function clickBoat(~, ~)        clickType = get(gcf, 'SelectionType');        XY = get(gca, 'CurrentPoint');        if strcmp(clickType, 'normal')            Y = XY(1, 2);            X = XY(1, 1);            set(DrawHatHdl, 'XData', [X - m* enlarge X + m* enlarge], 'YData', [Y - n* enlarge Y + n* enlarge]);        elseif strcmp(clickType, 'alt')            Y = XY(1, 2);            X = XY(1, 1);            enlarge=enlarge*1.1;            set(DrawHatHdl,  'XData', [X - m*enlarge X + m*enlarge], 'YData', [Y - n*enlarge Y + n*enlarge]);        end    endend: m5 O$ M1 x) j% k: O- j; j
    $ l4 Z+ }4 v( O/ `) b7 R$ x! K8 W0 r2 Y: X2 d+ F! Y6 V0 V
    小编根据原理又做了APP操作界面4 f! o" ~5 g/ d
    ! I- H- i3 l: q$ Z
    - `4 I$ h3 s6 d" x* H: @
    - -THE END- -* C9 K* ]9 j0 |/ E9 g) S
    . v# M. E* l' _, T/ g* Y; J
    源码下载:gitee下载:https://gitee.com/LoveMatlab/addHat
    1 A6 Z6 q  x! o) d4 s$ v/ n" T
    9 Y3 P. d- E* {* p( o
    + L3 v" f/ _- w" L# c1 {QQ 群下载:
    4 l3 ~9 s' k" K1 g. V, [% B& Y6 Z
    ! C5 t0 Z. C3 h# ?# x0 j) [( t$ O  Q& v% E$ G
    参考资料:
    * K. l+ _3 k8 d8 I. T& g【1】https://slandarer.blog.csdn.net/article/details/118368777【2】https://mp.weixin.qq.com/s/mRIImZK-bLJWrZwVtkrhfw
