点击上方蓝字关注我们
今天是520,Lvy来给大家表示爱意啦~
为什么大家都这么爱用神经网络呢?当然是因为它的效果确实好,做个传统的回归或者分类任务确实能达到不错的效果
MATLAB 新旧网络工具箱的测评
用MATLAB实现BP神经网络还是很容易的,以下是不是大家经常可见的神经网络构造方式了,很遗憾这种方式已经out了
net=newff(x_train_regular,y_train_regular,[6],{'tansig'});小编2022版本MATLABhelp newff发现它已经过时了,并且早就被遗弃了,不过用起来还是没问题的
不过小编发现了一个新的matlab神经网络工具箱函数【只有在MATLAB2021b 以上的版本才有】
net=fitrnet(x_train_regular,y_train_regular,"LayerSizes",6,'Activations',{'tanh'});
小编测试了一下这两种神经网络实现方法,发现确实是新版的fitrnet函数运算速度更快,效果更好
旧版实现回归方式
clc;clear;close all;load('abalone_data.mat')%%[m,n]=size(data);train_num=round(0.8*m); %自变量 x_train_data=data(1:train_num,1:n-1);y_train_data=data(1:train_num,n);x_test_data=data(train_num+1:end,1:n-1);y_test_data=data(train_num+1:end,n);x_train_data=x_train_data';y_train_data=y_train_data';x_test_data=x_test_data';[x_train_regular,x_train_maxmin] = mapminmax(x_train_data);[y_train_regular,y_train_maxmin] = mapminmax(y_train_data);%创建网络t1=clock;net=newff(x_train_regular,y_train_regular,[6],{'tansig'});% net=newff(x_train_regular,y_train_regular,[6,3,3],{'logsig','tansig','logsig','purelin'});% net=newff(x_train_regular,y_train_regular,6,{'logsig','logsig'});% net=newff(x_train_regular,y_train_regular,6,{'logsig','purelin'});% net=newff(x_train_regular,y_train_regular,6,{'logsig','tansig'});% %设置训练次数% net.trainParam.epochs = 50000;% %设置收敛误差% net.trainParam.goal=0.000001;% newff(P,T,S,TF,BTF,BLF,PF,IPF,OPF,DDF) takes optional inputs,% TF- Transfer function of ith layer. Default is 'tansig' for% hidden layers, and 'purelin' for output layer.%%激活函数的设置% compet - Competitive transfer function.% elliotsig - Elliot sigmoid transfer function.% hardlim - Positive hard limit transfer function.% hardlims - Symmetric hard limit transfer function.% logsig - Logarithmic sigmoid transfer function.% netinv - Inverse transfer function.% poslin - Positive linear transfer function.% purelin - Linear transfer function.% radbas - Radial basis transfer function.% radbasn - Radial basis normalized transfer function.% satlin - Positive saturating linear transfer function.% satlins - Symmetric saturating linear transfer function.% softmax - Soft max transfer function.% tansig - Symmetric sigmoid transfer function.% tribas - Triangular basis transfer function.%训练网络[net,~]=train(net,x_train_regular,y_train_regular);%将输入数据归一化x_test_regular = mapminmax('apply',x_test_data,x_train_maxmin);%放入到网络输出数据y_test_regular=sim(net,x_test_regular);%将得到的数据反归一化得到预测数据BP_predict=mapminmax('reverse',y_test_regular,y_train_maxmin);%%BP_predict=BP_predict';errors_nn=sum(abs(BP_predict-y_test_data)./(y_test_data))/length(y_test_data);t2=clock;Time_all=etime(t2,t1);disp(['运行时间:',num2str(Time_all)])figure;color=[111,168,86;128,199,252;112,138,248;184,84,246]/255;plot(y_test_data,'Color',color(2,:),'LineWidth',1)hold onplot(BP_predict,'*','Color',color(1,:))hold ontitlestr=['MATLAB自带newff神经网络',' 误差为:',num2str(errors_nn)];title(titlestr)disp(titlestr)运行时间:0.794
MATLAB自带newff神经网络 误差为:0.15142
新版实现回归方式
x_train_regular=x_train_regular';y_train_regular=y_train_regular';
t1=clock;net=fitrnet(x_train_regular,y_train_regular,"LayerSizes",6,'Activations',{'tanh'});%%figure;%训练过程中的LOSSiteration = net.TrainingHistory.Iteration;trainLosses = net.TrainingHistory.TrainingLoss;plot(iteration,trainLosses)legend(["Training"])xlabel("Iteration")ylabel("Mean Squared Error")%%%%% LayerSizes - Sizes of fully connected layers% 10 (默认值) | positive integer vector% Activations - Activation functions for fully connected layers% 'relu' (默认值) | 'tanh' | 'sigmoid' | 'none' | string array |% cell array of character vectors% LayerWeightsInitializer - Function to initialize fully connected% layer weights% 'glorot' (默认值) | 'he'% LayerBiasesInitializer - Type of initial fully connected layer% biases% 'zeros' (默认值) | 'ones'% ObservationsIn - Predictor data observation dimension% 'rows' (默认值) | 'columns'% Lambda - Regularization term strength% 0 (默认值) | nonnegative scalar% Standardize - Flag to standardize predictor data% false or 0 (默认值) | true or 1% Verbose - Verbosity level% 0 (默认值) | 1% VerboseFrequency - Frequency of verbose printing% 1 (默认值) | positive integer scalar% StoreHistory - Flag to store training history% false or 0 | true or 1 (默认值)% IterationLimit - Maximum number of training iterations% 1e3 (默认值) | positive integer scalar% GradientTolerance - Relative gradient tolerance% 1e-6 (默认值) | nonnegative scalar% LossTolerance - Loss tolerance% 1e-6 (默认值) | nonnegative scalar% StepTolerance - Step size tolerance% 1e-6 (默认值) | nonnegative scalar% ValidationData - Validation data for training convergence detection% cell array | table% ValidationFrequency - Number of iterations between validation% evaluations% 1 (默认值) | positive integer scalar% ValidationPatience - Stopping condition for validation evaluations% 6 (默认值) | nonnegative integer scalar% CategoricalPredictors - Categorical predictors list% vector of positive integers | logical vector |% character matrix | string array |% cell array of character vectors | 'all'% PredictorNames - Predictor variable names% string array of unique names |% cell array of unique character vectors% ResponseName - Response variable name% "Y" (默认值) | character vector | string scalar% Weights - Observation weights% nonnegative numeric vector | name of variable in Tbl% CrossVal - Flag to train cross-validated model% 'off' (默认值) | 'on'% CVPartition - Cross-validation partition% cvpartition partition object | [] (默认值)% Holdout - Fraction of data for holdout validation% scalar value in the range (0,1)% KFold - Number of folds% 10 (默认值) | positive integer value greater than 1% Leaveout - Leave-one-out cross-validation flag% 'off' (默认值) | 'on'% OptimizeHyperparameters - Parameters to optimize% 'none' (默认值) | 'auto' | 'all' |% string array or cell array of eligible parameter names |% vector of optimizableVariable objects% HyperparameterOptimizationOptions - Options for optimization% structure%将输入数据归一化x_test_regular = mapminmax('apply',x_test_data,x_train_maxmin);x_test_regular=x_test_regular';%放入到网络输出数据y_test_regular=predict(net,x_test_regular);%将得到的数据反归一化得到预测数据BP_predict=mapminmax('reverse',y_test_regular,y_train_maxmin);%%errors_nn=sum(abs(BP_predict-y_test_data)./(y_test_data))/length(y_test_data);t2=clock;Time_all=etime(t2,t1);disp(['运行时间:',num2str(Time_all)])figure;color=[111,168,86;128,199,252;112,138,248;184,84,246]/255;plot(y_test_data,'Color',color(2,:),'LineWidth',1)hold onplot(BP_predict,'*','Color',color(1,:))hold ontitlestr=['MATLAB自带fitrnet神经网络',' 误差为:',num2str(errors_nn)];title(titlestr)disp(titlestr)运行时间:0.601
MATLAB自带fitrnet神经网络 误差为:0.14456
一行命令实现贝叶斯优化神经网络超参数
你还在为调超参数烦恼嘛,不知道选择几层网络,几个神经元,用什么激活函数?那你一定不能错过这个MATLAB自带的神经网络调参工具,一句命令就可以实现自动调参
clc;clear;close all;load('abalone_data.mat')[m,n]=size(data);train_num=round(0.8*m); %自变量 x_train_data=data(1:train_num,1:n-1);y_train_data=data(1:train_num,n);x_test_data=data(train_num+1:end,1:n-1);y_test_data=data(train_num+1:end,n);x_train_data=x_train_data';y_train_data=y_train_data';x_test_data=x_test_data';[x_train_regular,x_train_maxmin] = mapminmax(x_train_data);[y_train_regular,y_train_maxmin] = mapminmax(y_train_data);
optimize_num=10;% 使用贝叶斯网络进行优化Mdl = fitrnet(x_train_regular,y_train_regular,"OptimizeHyperparameters","auto", ... "HyperparameterOptimizationOptions",struct("AcquisitionFunctionName","expected-improvement-plus",'MaxObjectiveEvaluations',optimize_num));%% 测试一下效果x_test_regular = mapminmax('apply',x_test_data,x_train_maxmin);x_test_regular=x_test_regular';%放入到网络输出数据y_test_regular=predict(Mdl,x_test_regular);%将得到的数据反归一化得到预测数据BP_predict=mapminmax('reverse',y_test_regular,y_train_maxmin);errors_nn=sum(abs(BP_predict-y_test_data)./(y_test_data))/length(y_test_data);
figure;color=[111,168,86;128,199,252;112,138,248;184,84,246]/255;plot(y_test_data,'Color',color(2,:),'LineWidth',1)hold onplot(BP_predict,'*','Color',color(1,:))hold ontitlestr=['MATLAB自带优化神经网络',' 误差为:',num2str(errors_nn)];title(titlestr)disp(titlestr)
观测到的最佳可行点:
Activations Standardize Lambda LayerSizes
___________ ___________ __________ __________
sigmoid false 2.9879e-07 31 1
妥妥的一键式优化,直接把激活函数,正则化系数以及网络层数和神经元优化出来了!
【数据和源码在好玩的MATLAB】的小公众号【Lvy的口袋中】回复关键词【新神经网络】领取奥~
可以关注一下小号【Lvy的口袋】,分享知识和生活~
点个在看你最好看 |
