查看: 137|回复: 0
【好玩的源码】绘制爱心
发表于 2021-10-28 00:12:00 | 显示全部楼层 |阅读模式
点击上方蓝字和“好玩的MATLAB”一起快乐玩耍吧!" k3 L9 I2 l# Q0 C) J. e
5 z& P7 T: A0 ^: O8 j
& l+ Z6 w% r  i/ _, P1 y' B4 M
& o& Z+ w3 u) ^; Y/ a9 v好玩的matlab% t" I5 y  j* p2 ^2 ~
带你学会不一样的matlab新玩法% l0 c" x7 ]3 h4 O( o1 S! y% `* r
2 ~7 x* b, y+ b今天给大家安排几个好玩的绘制爱心的代码!还不赶快给喜欢的人发一个,希望大家能够喜欢!6 X3 x$ w$ x$ l, j; ]0 _
01
! @  b- ?9 Q: |8 O) M' c# n  R绘制爱心1效果如下:: |0 G3 ~0 A/ f! ]$ L" @
6 y, `  D7 W0 f. x# p4 P' q
# i# i; j1 V' ~6 ]. wMatlab源码:  ^$ J* `5 L) e. x- N3 o, M( [
  • clc;clear;close all;figure('color',[0,0,0])x=linspace(-1,1,4000)*pi/2;y=(sqrt(cos(x)).*cos(200*x)+sqrt(abs(x))-0.7).*(4-x.^2).^0.01;scatter(x,y,10,-y-x.^2,'filled'); axis equal off;colormap(spring)
    5 M1 l7 f1 b2 R  ?$ {9 I4 b: J* [02* R/ K" ?3 B9 {' e6 a1 s
    绘制爱心2效果如下:
    & x/ g4 d7 h) {; j0 k* z1 G- K4 Z+ q  R* j) T9 M7 Q9 c
    , g" a: B1 v) Z% i4 G9 r2 Z  ^
    Matlab源码:
  • clc;clear%% 爱心的参数方程t=0:0.025:4*pi;x=16*sin(t).^3;y=13*cos(t)-5*cos(2*t)-2*cos(3*t)-cos(4*t);%% 动图画图并保存为GIFh = plot(x(1),y(1),'-.r','LineWidth',1.5);%h为Line对象axis([-20,20,-20,20]);axis offset(gcf,'color',[0,0,0])[A,map] = rgb2ind(frame2im(getframe),256);%getframe获取当前画面imwrite(A,map,'1.gif','LoopCount',inf,'DelayTime',1);pausefor idx = 2:2:length(t)    h.XData(idx) = x(idx);    h.YData(idx) = y(idx);    drawnow    [A,map] = rgb2ind(frame2im(getframe),256);    imwrite(A,map,'1.gif','WriteMode','append','DelayTime',0.1);  endfor idx = 2:length(t)    h.XData(idx) = x(idx);    h.YData(idx) = y(idx);    drawnow    [A,map] = rgb2ind(frame2im(getframe),256);    imwrite(A,map,'1.gif','WriteMode','append','DelayTime',0.1);  endtext(0,0,'我爱你祖国','HorizontalAlignment','center','FontSize',37,'color','r')
    8 D* p+ q0 C, T( b  P* O' J03
    2 M5 |8 j$ r! d; h5 {: l3 f绘制爱心3效果如下:
    , `8 Q# c1 P6 C* i- ^
    5 W' j. e' E. ?" {* P; e# ^6 g5 }) o/ ]5 q8 e6 S; N) z0 I
    . t; X; J, L- Z' R+ v
    Matlab源码:
  • clc,clearfigure('color',[0,0,0])syms xpausefor i=0:0.1:10    y=abs(x).^(2/3)+0.9*sqrt(3.3-x.^2).*sin(i.*pi.*x);    fplot(y,[-2,2],'-*r');    title(['$|x|^{2/3}+0.9\sqrt{3.3-x^2}sin(i\pi x)$','   i=',num2str(i,'%.1f')],'interpreter','latex','color',[1,1,1])    set(gca,'color',[0,0,0])    pause(0.001)end04
    4 z: x2 U7 d1 J9 Z& ^绘制爱心4效果如下:
    " J' `8 H. E# C! X# D, }  H/ c  w
    ! H5 Z8 g5 g5 V
    - e, b, M4 X# y. g
      i; j; j; f  W) LMatlab源码:
  • clc;clear;warning  offfigure('color',[0,0,0])for b=-10:1:40    clf;    x=[-1.6:0.01:1.6];    y=(sqrt(cos(x)).*cos(b.*200.*x)+sqrt(abs(x))-0.7).*(4-x.^2).^0.01;    plot(x,y,'r','LineWidth',2);    set(gca,'color',[0,0,0])    axis off    hold off    pause(0.3)end
    / W  k: ~6 H2 R6 x
    & a. S; \) m- F0 O+ m8 b好玩的matlab 1分钟前4 o2 f" `) P, N
    爱心源码我发了,关于怎么找女朋友?哪里找?小编的思路是:new一个对象,啥参数都可以自己设定。(程序员是不缺对象的,随时打开matlab都可以写一个结构体对象)
    / f: H  g5 V$ ^1 l  C* Z: ]
  • girlfriend.name='菲菲公主';girlfriend.age=18;girlfriend.Education='本科';girlfriend.height=165;%cmgirlfriend.weight=50;%kg “皮”一下很开心!希望本推文对大家有帮助!
    % e# x/ y# J7 w) B, n/ C( L; W* O好书推荐6 W6 X9 q. u9 U; o$ I( @
    参考资料:. D  c: S) {) J% ]! R' C
    【1】https://ww2.mathworks.cn/【2】https://idmatlab.blog.csdn.net/article/details/85941651" ?2 s( z4 D/ a- {3 x; c3 |7 A
    0 R+ u) ]/ d5 Q  P$ ?
    往期精彩回顾
    / J% ]- M, Y9 a9 S' d- H6 K
    ; n7 J7 ~8 l2 c3 e! D0 ?9 p* L推荐 | 【好玩的源码】MATLAB 绘制动态正弦函数推荐 | 【高级绘图】MATLAB怎么将图形局部放大推荐 | 【高级绘图】Matlab绘制阴影误差图        推荐 | 【高级绘图】绘图风格(1)绘制好看的笛卡尔坐标系
    ( a* _" \# @. u% [
    ( N% u( F+ Y, {- `8 w$ I4 X
    5 z+ A6 n8 _; q
    4 j! G) Z' n# ]6 \( V  e, z+ L* T- N8 V
    ↓↓↓ 点击"阅读原文" 【查看更多信息】
