查看: 119|回复: 0
QCN9274 & QCN6274 Wi-Fi 7 with Multi-Link Operation (**O) on X86 Devices
发表于 2025-2-27 10:03:25 | 显示全部楼层 |阅读模式
[color=rgba(0, 0, 0, 0.9)]Wi-Fi 7 with Multi-Link Operation (**O) on X86 Devices: A New Era of Connectivity
[color=rgba(0, 0, 0, 0.9)]As the world of wireless technology continues to evolve, the introduction of Wi-Fi 7 is nothing short of a ****-changer. With its potential for significantly higher speeds, lower latency, and enhanced reliability, Wi-Fi 7 is set to revolutionize industries and applications ranging from industrial IoT to high-performance consumer devices. At Wallys, we’re always driven by customer needs, and as part of our commitment to offering cutting-edge solutions, we’re focused on expanding the possibilities for Wi-Fi 7 technology—specifically by enabling Multi-Link Operation (**O) support on X86 platforms.
Expanding the Reach of Wi-Fi 7: A New Level of Compatibility
[color=rgba(0, 0, 0, 0.9)]Last year, we introduced X86 driver support for our Wi-Fi 6 module, DR9074, which enabled seamless integration across a broader range of motherboard platforms, not just Qualcomm devices. This support empowered our customers to experience high-quality, stable Wi-Fi data transmission and opened the door for new applications that demand reliable and high-throughput wireless connections.
* j( y1 Z9 {: H: J% P0 w9 |5 `
/ F- ~  n  R3 O# t- L* o& O
7 Z, q: y1 z& q  x) q
* ?3 n* {! J! I0 o8 V5 Z' F8 ]/ X
[color=rgba(0, 0, 0, 0.9)]With the introduction of Wi-Fi 7, cross-platform compatibility becomes even more critical. Wi-Fi 7 brings with it a new set of features designed to push the boundaries of wireless connectivity, and one of the most significant is Multi-Link Operation (**O). But to harness the full potential of **O, we need to ensure that our solutions can operate on multiple platforms—something we’re excited to announce we’re working on with our DR9274 (QCN9274) and QCN6274 Wi-Fi 7 modules.
/ \5 X+ \4 D' `[color=rgba(0, 0, 0, 0.9)]
7 U) z- {) |* _$ O
; v$ W/ O" F/ r* n5 G0 C5 ]  \wifi6 vs wifi7
2 o7 W7 H* u% j8 B
What is **O? And Why Does It Matter?
[color=rgba(0, 0, 0, 0.9)]Multi-Link Operation (**O) is one of the standout features of Wi-Fi 7. **O allows devices to transmit data across multiple frequency bands (like 2.4 GHz, 5 GHz, and 6 GHz) simultaneously. This multi-band transmission significantly improves throughput and reliability, while reducing latency and congestion, ****** it an ideal solution for environments that require high-speed and low-latency communication.
[color=rgba(0, 0, 0, 0.9)]In ****** terms, **O will enable your devices to leverage the full bandwidth potential of Wi-Fi 7, resulting in faster speeds, more stable connections, and more efficient use of available spectrum.
2 R9 v1 D" i2 ]7 W: y7 B2 O
" N5 Y0 ~: E% a' w3 r( N/ Y
" I/ R$ I6 h# @% K- b' U- ?" t( r
, j9 W1 {5 c( _: x* {1 y' J
Introducing the QCN9274 & QCN6274 Wi-Fi 7 Modules
[color=rgba(0, 0, 0, 0.9)]To enable the full potential of **O, we’re leveraging the power of QCN9274 and QCN6274—two of Qualcomm’s latest Wi-Fi 7 chipsets, both designed for high-performance applications.
2 l# Z6 C4 a' @' g
  • QCN9274 (Waikiki)
  • QCN6274 (Waikiki); q1 w" ?- w9 e5 Y
* w, R5 P4 D# P' l$ q  x& [% Y9 p- n
[color=rgba(0, 0, 0, 0.9)]. {+ B' z8 m4 M2 ]/ y3 b
9 ^5 s2 |1 d) P: I$ G/ D# u
**O
; w: n6 P' Y$ I2 j) U- Y4 I( R( H
[color=rgba(0, 0, 0, 0.9)]These two powerful chipsets represent the future of Wi-Fi 7 and provide the foundation for expanding compatibility across a variety of platforms. With **O support, both the QCN9274 and QCN6274 enable better utilization of the 2.4, 5, and 6 GHz bands, delivering faster speeds and more reliable connections.
0 n  p" w, g1 A5 T
& r% P2 Y) G9 C7 j1 e& {
: w9 H0 Q3 ?9 Q3 n" q/ R3 qwifi7 new features
8 B* Z" s. G4 V) u1 @
What Will **O Bring to Your X86 Devices?
[color=rgba(0, 0, 0, 0.9)]By introducing **O support for X86 devices, we’re pushing the envelope on what’s possible in wireless ***working. Users of X86 platforms will now be able to tap into the full power of Wi-Fi 7, unlocking:
4 B5 W( q3 h1 B' i5 i) P  _
  • Higher Throughput: With **O, data is split across multiple channels, leading to faster speeds and higher data rates, ideal for bandwidth-hungry applications like streaming, gaming, and industrial IoT.
  • Enhanced Reliability: **O ensures that devices can maintain stable connections, even in environments with interference or congestion, by balancing traffic across different frequency bands.
  • Reduced Latency: Faster communication between devices can significantly reduce lag and improve the responsiveness of real-time applications, from virtual reality to autonomous systems.
    ' M: |- B: U* b  r) W
8 a5 ]' D+ O0 q$ b
[color=rgba(0, 0, 0, 0.9)]The implications are significant. Wi-Fi 7, combined with **O, could tran**orm industries that rely on seamless, high-performance wireless connectivity—think smart cities, industrial automation, healthcare, and beyond.
( r' {7 [/ h, f# M% X) N; |* q[color=rgba(0, 0, 0, 0.9)]1 i9 k( y7 D7 W
  n6 {5 T$ y, O9 Y3 h
Wallys Adapter Card(wifi7 adapter card coming soon)
, L& b2 e' l2 i& y9 K4 V3 c! G6 G3 NWhat’s Next for Wi-Fi 7 on X86?
[color=rgba(0, 0, 0, 0.9)]At Wallys, we’re committed to ensuring that our solutions are as versatile and adaptable as possible. With the upcoming X86 driver support for DR9274 and **O functionality, you’ll be able to take full advantage of Wi-Fi 7 speeds and unlock new potential for your devices.
+ V$ f5 B: E! S. O[color=rgba(0, 0, 0, 0.9)]
' U2 y. v6 V2 h7 o( c
0 |6 n4 m. V9 j4 P# @3 t3 d; ?5 D
Thoughtput testing:achieve 8Gbps+ speed
" Y, `- n* M: t, h9 S6 _
[color=rgba(0, 0, 0, 0.9)]This new capability will open up new opportunities for a variety of applications, and we’re eager to see how our customers will integrate this powerful technology into their own use cases.
% d! P7 d8 o2 T: p8 k6 ~# Q1 g( j, s
[color=rgba(0, 0, 0, 0.9)]. F- @0 p& M: Y; O1 c
( l8 Y9 d: @. X# Y! y: A9 bwallys wifi7 M.2 card
6 G" @5 L9 ?6 {) z7 O" U; A
Are You Ready for the Future of Wireless Connectivity?
[color=rgba(0, 0, 0, 0.9)]With Wi-Fi 7’s blazing-fast speeds and **O’s ****-changing capabilities, the possibilities are endless. How do you envision using Wi-Fi 7 with **O on your X86 platforms? Whether it’s enhancing your industrial IoT devices, supporting next-gen gaming applications, or powering high-bandwidth communications, the potential is vast.
[color=rgba(0, 0, 0, 0.9)]At Wallys, we’re excited to continue innovating and providing the tools you need to stay ahead in the rapidly evolving wireless landscape. If you’re interested in learning more about our Wi-Fi 7 solutions or how we can help with your next project, feel free to reach out to us at [color=var(--color-action)][backcolor=var(--artdeco-reset-link-background-color-transparent)]sales1@wallystech.com.
[color=rgba(0, 0, 0, 0.9)]Let’s shape the future of connectivity, together.
$ J6 y3 i) ~- p5 G7 I! q[color=rgba(0, 0, 0, 0.9)]
/ |9 Y0 W" ^/ ~4 f  G) r3 u. s
' r- N1 b9 x" L( e& Z
1 [0 T+ |: s0 j' V/ B+ H, S; a4 K6 w# z) S# q8 L% y
