查看: 3995|回复: 3
HOTFIX VERSION: 019
发表于 2013-11-22 10:14:19 | 显示全部楼层 |阅读模式
本帖最后由 深圳-绿皮 于 2013-11-22 10:14 编辑 . n$ G8 i; L1 I9 z  B
; S  J0 O( v: c" Z7 tDATE: 11-15-2013   HOTFIX VERSION: 019. K* i, p0 V3 {. h& F
' @1 _# N! S7 K& a2 S& k& ICCRID   PRODUCT        PRODUCTLEVEL2   TITLE
  _+ V+ V: U( N0 {, b$ Y2 P# J- y8 \===================================================================================================================================
- X0 W  M" j$ j* O1176155 CONCEPT_HDL    CORE             Graphics remnants with 16.6 QIR 3
! Z: Q5 Y  K9 H9 G7 W1178272 CONCEPT_HDL    OTHER            Verilog netlist does not include split blocks correctly9 e* i! _% ~5 o7 N5 n5 p( ]  q
1190782 FSP            FPGA_SUPPORT     Support for Altera > 5SGXEA9N2F45 device.
- o1 u/ G) h, H5 R9 Z. m6 x1194140 ADW            LRM              SYNC_PROPERTIES is not resolving issues a based sync_properties settings
8 B0 W& g3 S6 P, |- p1195744 APD            EDIT_ETCH        Diff_Pair routing fails on certain Uvias in the pair.5 e7 K9 l5 A) e
1196704 allegro_EDITOR INTERFACES       ENH: During ipc2581 export checkboxes corresponding to 縈iscellaneous Image Layers� should automatically get selected
. }0 E  Q. v+ f# g& |/ Z7 `. Q1198340 ALLEGRO_EDITOR OTHER            Multiple -product option on the Allegro command line does not access the second -product( _5 [( g( Z1 T
1198596 ALLEGRO_EDITOR INTERFACES       When copper thickness is increased for the outer layers, step Viewer does not show correct component position.
3 p7 I, U8 j4 y+ b- m/ D1199673 PCB_LIBRARIAN  OTHER            Component Browser fails to load footrpints if they are set with UNC path+ \8 C+ T) O8 z  K$ `
1199889 ALLEGRO_EDITOR DATABASE         Allegro crashing with latest hotfix.
# N. q. Z9 U) q1200303 ALLEGRO_EDITOR GRAPHICS         3D Viewer does not update after changing STEP model mapping
/ r8 _$ W; W; C: u( u1200449 ALLEGRO_EDITOR REPORTS          Allegro crashes when generating Net Loop Report.
2 R7 u8 P- p$ H% d  \1200915 ALLEGRO_EDITOR DATABASE         Reducing accuracy of this specific design crashes Allegro
) {+ G% ]" x$ P- W# R$ C! @1201011 ADW            COMPONENT_BROWSE Component Browser crashes in DB mode
; k' _6 {' G3 V4 d: p6 N1201376 ALLEGRO_EDITOR INTERFACES       Allegro hangs when trying to map a specific STEP model to a package drawing.7 [% Y/ c0 s7 z1 u3 ?
1201897 SIP_layout     IMPORT_DATA      BGA Pin Colors not matching the Colors defined in the Symbol Spreadsheet after updating.# [% K" a, q# Q& {
1202709 ALLEGRO_EDITOR INTERFACES       STEP File generated from Allegro is not overwritten when the variable "set ads_textrevs
1 p9 A* {. ~2 _8 _" c1202820 ALLEGRO_EDITOR INTERFACES       Different xml generation for same step model on S106 and S0175 F  M' A0 S# w. H3 \8 c
1202842 ALLEGRO_EDITOR INTERFACES       Step model invisible for one pin dra in allegro 16.6 symbol editor; N9 s; q& W3 s
1202983 ALLEGRO_EDITOR SHAPE            Shape voiding creates DRC with Route Keepout- Y* X* R" _& _/ y9 e$ ^3 }
1203125 ALLEGRO_EDITOR OTHER            Exporting STEP file with External copper enabled does not show all copper when viewed with Solid Edge or Inventor
. ?2 }/ x4 X" L2 W, y1203236 ALLEGRO_EDITOR INTERFACES       IPC2581 output with crosshatched shape is not correct
7 Q) K9 e& E. l5 o* D6 X1203995 CONCEPT_HDL    CHECKPLUS        CheckPlus rule, local_signal_no_offpage_body, getting an incorrect failure.
: S' z2 \; C9 x( G1204629 ALLEGRO_EDITOR SKILL            axlUIDataBrowse crashes the editor or returns error
7 L. S" e  n  c2 n: c  c3 r1204640 SIP_LAYOUT     DIE_EDITOR       Concurrent co-design update fails
1 I' _! H4 {" \% J# J$ g3 ]1204881 SIP_LAYOUT     BGA_GENERATOR    Pin numbers are messed up after deleting a pin at a staggered bga
. t. H8 T3 s0 H: g2 l9 k! _) e1204885 CONCEPT_HDL    CONSTRAINT_MGR   Cant assign discrete models after the wrong model was removed.! X7 l% w1 k( O9 D2 s3 Q; ]# ~
1205374 ALLEGRO_EDITOR OTHER            pdf out command creates incorrect drill Symbol Characters placement in pdf file when setting film mirrored.
; c& Q1 c9 v( O3 s4 ^1205729 SIP_LAYOUT     DIE_EDITOR       update of codesign db fails on exit from die editor
8 Q! I; p" Z) _, U: A4 ^4 v# J, g, u" Q! c1205801 ALLEGRO_EDITOR OTHER            Tool crash when do export IPF.3 s- }4 t) i8 H; E. K0 j- d
1205881 CONSTRAINT_MGR OTHER            In CMGR , Objects > Create crashes Allegro0 \& n1 \. h$ _9 G" [
0 C# s) u7 r( \7 H( h2 m, U
' j0 s& T2 U: c) g& S' n; D/ Y* Y
6 x# [+ ?8 |3 S5 Q0 X; Ihttp://pan.baidu.com/s/13S6yr
* {1 E& S$ L8 t2 L
发表于 2017-3-7 02:29:11 | 显示全部楼层
支持 学习下新的东西
发表于 2022-4-26 09:12:11 | 显示全部楼层
666666666666666666666666666666666666666
7 h  y8 K! [3 v7 H, ~! q
发表于 2022-4-30 19:39:17 | 显示全部楼层
支持 学习下新的东西
